Is It Possible to Solve This Diffusion Equation via Separation of Variables?
Remixex
$$\frac{\partial U}{\partial t}=\nu \frac{\partial^{2} U}{\partial y^{2}}$$
$$U(0,t)=U_0 \quad for \quad t>0$$
$$U(y,0)=0 \quad for \quad y>0$$
$$U(y,t) \rightarrow {0} \quad \forall t \quad and \quad y \rightarrow \infty$$
This is a diffusion problem on fluid mechanics, but it's more of a math problem so i posted it here.
I'm trying to solve this via separation of variables (the textbook uses a "similarity" method I've never seen before, and concludes the function U must be erf) is it even possible to reach an analytic result via SV?
The first boundary condition is what gets me, I tried
$$U_{0} e^{{k^{2}t}} e^{{-\frac{k}{\sqrt{\nu}}y}}$$
But it clearly doesn't work for any boundary condition except the last.
I don't think sinusoidal is the answer here either because it must eventually converge to zero, for every t.
Is there really no analytic answer?
Please show your separation of variables and the resulting differential equations.
Use Laplace transforms with respect to ##t##. Let
$$W(y,s) = \int_0^{\infty} e^{-st} U(y,t) \, dt $$
be the Laplace transform. Then, using standard properties of Laplace transforms, we get the DE
$$\nu W_{yy}(y,s) = s W(y,s) - U(y,0) = s W(y,s),$$
where ##W_{yy} = \partial^2 W / \partial y^2##.
Also: ##U(0,t) = U_0## implies that
$$W(0,s) = \frac{U_0}{s} $$
Finally, the initial value theorem requires that ##\lim_{s \to \infty} s W(y,s) = 0## for ##y > 0##.
These are enough to determine ##W(y,s)##. Then it is just a matter of taking the inverse Laplace transform of ##W(y,s)## to get ##U(y,t)##.
Separation of variables will never work in this example, simply because it leads to the wrong kind of function.
THANK YOU :D
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
