Very Relativity problem(True or False)?
  • Thread starter Thread starter SAT2400
    Relativity
The discussion centers on a relativity problem involving length contraction. A stationary meter stick along the y-axis is observed by a moving observer along the x-axis. The key point is that length contraction occurs only in the direction of motion, meaning the meter stick's length remains unchanged in the y-direction. Therefore, the claim that the moving observer measures the stick as less than 1 meter is false. The conclusion is that the observer will measure the meter stick's length as 1 meter.
SAT2400
Very URGENT!Relativity problem(True or False)??
YOu have a meter stick located at rest along y axis. Another person moving along x-axis
will measure the length of meter stick to be less than 1 meter.
lorentz contraction
I think it's true..but my friend said it's false...Is it true or false?
I believe an object only experiences contraction in the direction of motion. The y-axis will not contract if the observer is moving in the x-direction.
False ; )
so it's false??
