How to Connect VHDL Counter Output to a Binary Decoder?
To connect the output of a VHDL 5-bit counter to a binary decoder, define the decoder outputs and assign each bit of the counter's output (c) directly to the decoder's outputs. This can be done without using a process, simplifying the connection. Alternatively, the counter output can be defined as an array, allowing for easier mapping to the decoder. The provided VHDL code successfully implements a synchronous load feature for the counter. Properly linking the counter output to the decoder will effectively display the counter's state.
tetooo_2006
structure or behavior VHDL code of a 5-bits binary counter with a sync. load signal to preset the counter to a specific initial state. the output of the counter (Q0 to Q4) are connected to a binary decoder that shows the state of the counter.
I wrote the code of 5 bits counter
Code:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
ENTITY counter IS
PORT ( count : OUT unsigned (4 DOWNTO 0);
load : IN STD_LOGIC;
pre :IN unsigned (4 DOWNTO 0);
Clk : IN STD_LOGIC);
END counter;
ARCHITECTURE Behavioral OF counter IS
SIGNAL c : unsigned(4 DOWNTO 0) := "00000";
BEGIN
count <= c;
PROCESS(Clk)
BEGIN
IF( rising_edge(Clk) ) THEN
IF(load = '1') THEN
c <= pre;
ELSE
c <= c + 1;
END IF;
END IF;
END PROCESS;
END Behavioral;
I want to connect the output to a binary decoder that shows the state of the counter
how can i do that?
You can just define the decoder outputs and then assign each bit of c to an output. It doesn't have to be a process. Alternatively, you can just define c as an output (array) instead of a signal.
