Vibration Massless spring static equilibrium
The discussion centers on a hypothetical massless spring fixed at one end, exploring its behavior under static equilibrium when a force is applied and then removed. When the force is removed, the spring is expected to vibrate around its equilibrium point, but this scenario is deemed unphysical due to the absence of mass. Participants note that applying a force to a zero mass leads to contradictions in classical physics. The conversation highlights the impracticality of discussing a truly massless spring, suggesting that even a negligible mass should be considered for meaningful analysis. Ultimately, the consensus is that the concept lacks physical validity without a defined mass.
Gunmo
Let us imagine that there is a Massless spring with fixed at one end.
Unloaded length = L
Spring constant: = k
Mass = 0The spring is at static Equilibrium
Force: F
Displacement: d
F = k d,
elongated length: L+d
If I remove F, what will happen ?
1. Spring return to the original length: L and Stop moving
2. Spring length vibrate between "L - d" and "L+d"
Note: there is no mass, damping, friction.
Its possible to think and give some answers but it seems to me that they will be non-sense. And because this question is actually useless and non-physical (there is no massless spring!), I think its better that you don't ask this question and don't face such non-sense answers because of nothing!
When you remove the force F it gets vibrating around the equilibrium point L and keeps so provided there is no dissipating forces like the air resistance to deplete the vibrational energy of the spring.
That's what any real spring would do, but OP has carefully specified a massless spring. As Shyan says, there is no solution in that case - we're applying a non-zero force to a zero mass and that situation is unphysical.
I understand. I was assuming that there is still a little mass in order to involve it in the vibration. Otherwise, it is nonsense to think of vibrating a massless spring. But I don't think that is what he means, i.e. we don't have any physical spring to be totally massless. By M = 0 I think he means an infinitesimal mass, say of order epsilon, though. He should specify..
I was thinking about another possibility, but as we are in classical physics you are right.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
