How Does Touching a Violin String Affect Its Frequency?
Touching a violin string at L/3 creates a node, effectively dividing the string into two segments. The tension and mass of the string remain constant, allowing for the calculation of the lowest frequency produced. The fundamental frequency can be determined using the formula f1 = 1/2L sqrt[F/μ], where μ is the mass per unit length. The new length for frequency calculation is 0.22m, which corresponds to the longer segment of the string. This approach confirms the correct understanding of how touching the string alters its vibrational characteristics.
clipperdude21
[SOLVED] Violin String and Waves
1. A violin string of length 0.33m and mass 50g is under a tension of 40N. A violin player touches the string a distance L/3 from one end, which produces a node at that point. What is the lowest frequency that can now be produced on the string?
2. I have several equations but they involve the funamental frequency
3. I tried solving this problem using the equation f1= 1/2L sqrt[F/mew] where mew is the mass per unit length. For the L i used 0.33- 0.33/3 to get 0.22m. This is the part I am not sure about. Is this the new length or is something else up. Thanks!b]
There are effectively two strings now, with the same T/mew ratio. The lowest note would be the fundamental harmonic of the longer portion.
great, so i did it right. Thanks!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
