Read the manuel that came with your meter.
  • Thread starter richard7893
  • Tags
    Circuits
In summary, to obtain an accurate reading of potential difference with a voltmeter that has finite resistance, a resistor must be placed between the leads of the voltmeter. This may seem counterintuitive, but it is necessary to account for the resistance of the voltmeter in the circuit. However, with the advancement of technology, modern electronic voltmeters have significantly higher resistance and may not have a significant impact on the circuit.
richard7893
For voltmeters with a finite resistance placed in a circuit, What can be done to get a correect reading of potential difference? my teacher said you would have to place a resistor between the leads of the voltmeter to get a close to correct reading, but I am just not quite wrapping my head around this idea.
It doesn't make sense to put a resistor across the meter (unless you mean a resistor already in the circuit).
There isn't much you can do other than to learn the resistance of the meter (often stated on the face of the meter) and do some calculations to see how it is affecting the circuit.
At one time this was a serious problem because Voltmeters had something like 20K ohms resistance per volt on the range used. However, electronic Voltmeters usually have much higher resistance due to a field affect transistor on the front end. If you have a modern meter it is unlikely that its resistance is affecting a circuit significantly.
I would like to clarify that the manual that came with your meter is the best resource for understanding how to use and interpret its readings. However, in response to your question about getting a correct reading of potential difference when using a voltmeter with finite resistance, your teacher is correct in suggesting the use of a resistor between the leads of the voltmeter.
This is because the finite resistance of the voltmeter itself can affect the overall resistance of the circuit and therefore alter the potential difference being measured. By adding a resistor in series with the voltmeter, you are essentially creating a voltage divider circuit, which allows for a more accurate reading of potential difference.
In simpler terms, the added resistor helps to balance out the resistance in the circuit and allows for a more precise measurement of potential difference. I understand that this concept may be difficult to grasp, but it is a common practice in electrical measurements and is necessary for obtaining accurate results.
I would recommend further reading and experimentation with voltage divider circuits to gain a better understanding of this concept. Additionally, consulting with your teacher or a more experienced scientist can also help clarify any confusion you may have. Remember, as a scientist, it is important to always question and seek understanding in order to make accurate and reliable measurements.
1. What is a voltmeter and how does it work?
A voltmeter is an electrical instrument used to measure the voltage or potential difference between two points in an electrical circuit. It works by connecting the two points in the circuit with a low resistance wire, which allows the current to flow through the voltmeter and display the voltage reading on its scale.
2. How is a voltmeter different from an ammeter?
A voltmeter measures voltage, while an ammeter measures current. Voltmeters are connected in parallel to the circuit, while ammeters are connected in series. Additionally, voltmeters have a high resistance to prevent the flow of current, while ammeters have a low resistance to allow the current to flow through them.
3. Can a voltmeter be used to measure AC and DC voltage?
Yes, there are voltmeters specifically designed to measure AC (alternating current) and DC (direct current) voltage. It is important to use the correct type of voltmeter for the type of voltage being measured, as using the wrong type can result in inaccurate readings or damage to the voltmeter.
4. What is the purpose of using a voltmeter in a circuit?
A voltmeter is used to measure the voltage at a specific point in a circuit, which can help in troubleshooting and diagnosing any issues with the circuit. It can also be used to ensure that the correct amount of voltage is being supplied to a component in the circuit.
5. How do you choose the right voltmeter for a circuit?
The right voltmeter for a circuit depends on the voltage range that needs to be measured. It is important to choose a voltmeter with a voltage range that is higher than the expected voltage in the circuit. Additionally, the type of voltage (AC or DC) and the accuracy of the voltmeter should also be considered when choosing the right one for a circuit.
14K
10K
