Calculating Voltage Across a Capacitor in a Series Circuit
To calculate the voltage across a capacitor in a series circuit with a resistor and battery, the correct approach involves using the formula for current over time as the capacitor charges. The time constant (RC) was miscalculated due to an error in the capacitance value, which should be 4.5 × 10^-3 F instead of 4.5 × 10^3 μF. The voltage across the capacitor can be determined by subtracting the voltage drop across the resistor from the total voltage supplied by the battery. After correcting the calculations, the voltage across the capacitor after 4.62 × 10^3 seconds is found to be 13.6 V. Accurate calculations are crucial for obtaining the correct voltage across the capacitor in such circuits.
roam
A capacitor of 4.50 × 103 μF is connected in series with a resistor of 820. kΩ, a perfect switch, and a 19.0 V battery. Initially there is no charge on the capacitor, and the switch is open.
What will the voltage across the capacitor be 4.62 × 103 s after the switch is closed?
First I used the equation for current as a function of time for a capacitor being charged:
I(t)=\frac{\epsilon}{R}e^{-t/RC}
RC= 820000 \times (45 \times 10^{-6}) = 36.9
t/RC= (4.62 \times 10^3)/36.9=125.2, so
\frac{19}{820 \times 10^3} e^{-125.2} = 9.8 \times 10^{-6}
Now I use V=IR to find the voltage:
(9.8 \times 10^{-6}) \times (820000) =8 \times 10^{-54}
But this is the wrong, the correct answer must be 13.6 V. So what's wrong? I appreciate it if anyone could show me how to do this problem...
hi roam! :smile:
your RC has the wrong power of 10 :cry:
In addition to the above it seems that you are attempting to calculate the voltage across the resistor(Vr) and not the capacitor(Vc).That's okay if you remember and use the fact that Vc+Vr=19V
For the capacitance, don't you mean 4.5 X 10-3? (There is already a 10-6 factor built into the "μ" part of μF)
Your time constant is off by a couple orders of magnitude, so you'll have to do the above operation again.
But using V = IR gives you the voltage drop across the resistor. In order to find the voltage across the capacitor, you'll need to subtract that from the 19 V supply.
[Edit: Oh my, looks like tiny-tim and Dadface beat me to the answer. I must learn to work/type quicker. :-p]
And that V=IR calculation is out by a factor of 10^54. Calculator error.
It worked. Thanks a lot guys.
