Voltage and Current lab report help
In summary, you are graphing a nonohmic material and it has a different resistance at different temperatures than an ohmic material.
ajenkin9
I'm working on a basic physics lab report (not homework) and I'm trying to understand something better. We're establishing a relation between voltage and current using Ohms law. It goes as follows:
We apply different voltages to two materials and record the current in order to determine the resistance. The two materials are a resistor and a light bulb. My problem has occurred when graphing though.
I know that the relationship for an ohmic material is linear, therefore it's simply (1/R). This would be true for the resistor. The lightbulb however is a nonohmic material, therefore it's not a linear relationship.
The way my graph looks is not the same as in the book though. The book shows a graph which looks like an exponential function (x^2), approaches a verticle asymptote. My graph for the lightbulb though looks opposite (looks more like a sqrt function) and approaches a horizontal asymptote. When looking online I saw a V versus I graph for a filament and it looked the same as mine.
My question is, why is this? Why do I have a different graph than what the book shows for a nonohmic material, but I see other "filament" graphs look the same as mine.
Thanks.
Light bulbs have a low resistance at room temp. This resistance increases as much as 15 times at operating temperature. So the resistance is proportional to the applied voltage.
From Wikipedia
"The cold resistance of tungsten-filament lamps is about 1/15 the hot-filament resistance when the lamp is operating. For example, a 100-watt, 120-volt lamp has a resistance of 144 ohms when lit, but the cold resistance is much lower (about 9.5 ohms)"
From Wikipedia
I understand that it's a nonlinear relationship because R=R0(1+[tex]\alpha[/tex](T-T0)). My confusion is why does the relationship differ for two, nonohmic materials. The book depicts a graph that shows a horizontal asymptote, yet my graph looks as though I have a vertical asymptote, as well does a graph from wikepedia for a filament depict the same thing. So why does one slope approach zero while the other slop approaches 1?
You say 'nonohmic' yet the tungsten filament is absolutely ohmic. It's just different resistance at different temperatures, as are most ohmic resistors. Since it's designed to work at about 1000C the temp variation is large. Note that the typical coiled filament, when unrolled is about 20inches long.
Varistors are non-ohmic. I suggest you google Wiki for a description.
1. What is the purpose of a voltage and current lab report?
The purpose of a voltage and current lab report is to document and analyze experiments conducted to measure the relationship between voltage and current in a circuit. This helps to understand the behavior of electrical components and their role in various circuits.
2. How do you measure voltage and current in a circuit?
Voltage is measured using a voltmeter, which is connected in parallel to the circuit. Current is measured using an ammeter, which is connected in series to the circuit. Both measurements are taken while the circuit is powered on.
3. What is the difference between voltage and current?
Voltage is the potential difference between two points in a circuit, measured in volts. It is responsible for the flow of electrons in a circuit. Current is the rate of flow of charge, measured in amperes. It is the actual movement of electrons through a circuit.
4. How are voltage and current related?
According to Ohm's law, voltage and current are directly proportional to each other. This means that as voltage increases, so does the current, and vice versa. This relationship is represented by the equation V = IR, where V is voltage, I is current, and R is resistance.
5. What can affect the voltage and current in a circuit?
The voltage and current in a circuit can be affected by the type and number of components in the circuit, the type of power source, and the resistance of the circuit. Changes in these factors can alter the relationship between voltage and current, as well as the overall behavior of the circuit.
