Voltage Divider - Understanding Two Circuits
In a voltage divider circuit with equal resistances, the output voltage can be calculated differently depending on the reference point. For a circuit with +5V and ground, the output is 2.5V. In a split supply scenario with +5V and -5V, the output is 0V, as the ground is considered the midpoint between the two voltages. The confusion arises from the definition of ground, which can vary based on the power supply configuration, whether single rail or split supply. Understanding these references is crucial for accurate voltage calculations in circuits.
autopsygreen
Very silly doubt...If say I had a voltage divider circuit with 2 equal Resistance say R applied between
1.V=5v and ground
2.V=5V and V=-5V
Whats the answers and what the difference?
I guess the answer for the 1 Q will be (5/2)...
Please explain the second ...Thank you
(5v - -5v)/2
0v
What confuses me is then why is the negative terminal said to be connected to ground.
Shouldnt that mean the ground and -5v are at same potential
depends on if its a single rail supply...
+5V and GND (0V or negative line of power supply)
or a split supply where you have say...
+5V, 0V, -5V where the 0V rail may be connectd to GND via the PSU case and mains earth
take a 12V battery, you have a + and - terminal --- from a circuit point of view the - terminal can be called 0V
now take a mains sourced 12V power supply, you have a +12V rail and a -(neg) 0V rail.
that negative rail may be floating ie. not connected to the case of the equip. Or it may be connected to the case and that case is also connected to GND via the Earth lead of the mains cable.
just a few random thoughts ;)
Dave
By stipulating a +5 and -5V supply, you are implying that there is a 'zero volts' somewhere in the power supplies, connected to ground which defines their voltages wrt ground.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
