Voltage drop across a capacitor
The discussion focuses on calculating the energy stored in a parallel plate capacitor with a positive charge Q and a negative charge -Q. The electric field between the plates is 100 kV/m, with an area of 2 × 10-3 m2 and a separation of 6 × 10-3 m. The capacitance was calculated using the formula C = kEoA/Separation, resulting in a value of approximately 2.95 pF. The voltage drop across the capacitor was confirmed to be calculated using Q = ∆V*C, clarifying the approach to finding the energy stored.
  • Understanding of parallel plate capacitors
  • Familiarity with electric field calculations
  • Knowledge of capacitance formulas
  • Basic principles of energy stored in capacitors
  • Study the derivation of capacitance for different geometries
  • Learn about the effects of dielectrics on capacitance
  • Explore energy storage calculations in capacitors
  • Investigate the relationship between voltage, charge, and capacitance
Students studying electrical engineering, physics enthusiasts, and anyone involved in capacitor design and analysis will benefit from this discussion.
zooboodoo
The left plate of a parallel plate capacitor carries a positive charge Q, and the right plate carries a negative charge -Q. The magnitude of the electric field between the plates is 100 kV/m. The plates each have an area of 2 × 10-3 m2, and the spacing between the plates is 6 × 10-3 m. There is no dielectric between the plates.
Calculate the energy stored in the capacitor.
q=vc , PE=c*v^2/2 , PE=Q^2 / 2C , PE=QV / 2
I calculated the Capacitance by C=kEoA/Separation = (2.95133333333333e-012)
I also calculated Q by E * Eo *A= Q = 1.7708e-9
I wasn't sure if "Voltage drop" entailed a different equation? I've gone through the powerpoints from my class and have not seen any other equations. My book hopefully comes in the mail soon :-\ any help would be appreciated
I believe that would entail Q=∆V*C which you've already got up there :smile:
Sigh, power of 10 error. It was the right equation, thanks though.
