What Voltage Does a Bird Feel on a Power Line?
The discussion focuses on calculating the voltage a bird feels while standing on an electric transmission line carrying 2210 A. The key parameters include the line's resistance of 3.32E-5 Ω per meter and the distance between the bird's feet, which is 3.80 cm. To find the voltage difference, the calculation involves using the formula for voltage drop across a resistor, specifically over the given distance of the wire. It is clarified that the bird's characteristics are irrelevant for this calculation, as the voltage drop is determined solely by the wire's resistance and the current. The confusion about multiplying by two arises from the context of two-conductor systems, which is not applicable in this scenario.
Liketothink
A bird stands on an electric transmission line carrying 2210 A, as seen in the figure below. The line has 3.32E-5 Ω resistance per meter and the bird's feet are 3.80 cm apart. What voltage does the bird feel?
R=sigma(L)/A
I=V/R
I wanted to solve for V of the bird, but neither the resistance of the bird nor the area of the bird is given. Help?
  • 04b31d68e2234a83c0c61e9728327049992c835e84eb4b662b1c6a6df2250a666aad63f7107f7f1e45b970cc510c51b7.gif
You are trying to find the voltage difference between the two points on the wire.
Think of the section of wire as a resistor
You are asked to find the potential difference between the birds legs. You do not need to know anything about the bird to find this. Your are given a resistivity, a distance and a current. Find the voltage.
I think you are being asked to calculate the difference in potential (voltage) between the bird's feet. Just leave the bird out of it and calculate the voltage drop over 3.8 cm of transmission line.
Edit: Oops! Upstaged TWICE
Ok so I got it by using voltage loss=amps*wire resitance/meter*distance
Usually this equation is
voltage loss=amps*wire resitance/meter*distance*2 wires
Why was it not necessary to multiply the answer by 2 in this case?
Where did the 2 come from ?
I thought that was the equation for voltage loss. Is it not?
Is the "2" perhaps included in that to calculate the voltage loss over a 2-conductor cable, like a lamp-cord?
