How Plaque Reduces Artery Radius: Calculating with Poiseuille's Law
  • Thread starter Thread starter cyberdx16
    Pressure Volume
The discussion focuses on calculating the reduction in artery radius due to plaque formation using Poiseuille's Law. A scenario is presented where the flow rate in an artery has decreased to 30% of its normal value, with a corresponding 30% increase in pressure difference. Participants clarify the correct application of the formula, with one contributor calculating that the radius is reduced by 14.4%. The conversation highlights the implications of significant occlusion, noting that an 80% blockage is particularly concerning for exercise tolerance and oxygen demands. Accurate calculations are essential for understanding the impact of arterial blockages on health.
cyberdx16
When physicians diagnose arterial blockages, they quote the reduction in flow rate. If the flow rate in an artery has been reduced to 30% of its normal value due to plaque formation, and the average pressure difference has increased by 30%, by what factor has the plaque reduced the radius of the artery?
Poiseuille's Law.
what i used was R=(.7/1.3)^.25 and get that only 85.6% of the radius of the artery is available, and has been reduced by 14.4%
I think you want to use .3 in the numerator, ie
flow is now 30 percent of original, not been reduced by 30%
wouldn't the presure rate be increased by .3 so from its original, which is 1 and add .3 for the increase. But yeah i just tried .3 and it didnt work
Its both .3 and 1.3, (.3/1.3)^.25 is that what you tried?
yeah you are right denverdoc! thx
NP. FYI when occlusion reaches 80 percent and above, bad news. This guy has lost some exercise tolerance but still in decent shape re meeting oxygen demands.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
