Volume and surface area of a cylinder
To find the ratio of the volume to the surface area of a cylinder, the volume is calculated as V = πr²h and the surface area as A = 2πr(h + r). The discussion emphasizes the need to compute the ratio V/A, which simplifies to (d²πh)/[(2πdh) + (2πd²)], where d represents the diameter. Participants clarify that d is not the radius and suggest further simplification of the ratio. The conversation focuses on correctly identifying the dimensions and applying the formulas to achieve the desired result.
Paulo Serrano
I need the ratio like in the image below
http://img228.imageshack.us/img228/4015/foiessa.jpg
I guess as a function of D.
Volume of a cylinder: pi*r^2*h
Area: 2*pi*r*(h+r)
No clue.
You have expressions for the area and volume, you are told to compute the ratio
\frac {Volume} {Area}
What is your problem?
The area of a cylinder, as far as I remember, is: 2*pi*r*h +(2*pi*r^2)
Now find the the volume, and divide that by area.
V= d^2*pi*h
A= (2*pi*d*h) + (2pi*d^2)
And now write V/A = (d^2*pi*h)/[(2*pi*d*h) + (2pi*d^2)]
I hope I am right, and that it helps! :)
That is a good start. Now do some simplification.
d isn't the radius though.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
