Volume of solids rotating about two axises
PirateFan308
Find the volumes of the solids revolution obtained by rotating the region about the x-axis and the y-axis.
y=2x-x^2, y=0
I know how to get the volume of a function that is rotating around one axis, but the "y=0" is confusing me. Because y=2x-x^2 is a parabola (with a max at (1,1)), so when I picture it, it looks like a squished donut (with the hole having no area), where a cross sectional area of the donut is shaped like a football with the area being 4/3 (integral of f(x)=2x-x^2 from 0 to 2). The outer radius will be 2 and the inner radius will be 0.
Is this correct, or am I completely off track? Also, what does the y=0 mean? Thanks
y=2x-x^2, y=0
y=0 is the lower boundary of the region.
As I read it, this is actually two problems: 1) Find the volume when the region is revolved around the x-axis. 2) Find the volume when the region is revolved around the y-axis.
Also, you should sketch each of the solids of revolution. When you revolve the region around the x-axis, you get something that looks a little like a football. When you revolve the region around the y-axis, you get something like the upper half of a bagel (what you described as a squished donut).
For the two shapes, you'll need to choose what your typical volume element is - either a disk or a shell. In neither case is the outer radius fixed.
Thanks!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
