W = F d cos θ Is Algebra Okay for Work?
  • Thread starter Thread starter peacerosetx
    Algebra Cos Work
The discussion revolves around calculating work using the formula W = F d cos θ, specifically in the context of an exam preparation problem. The user correctly identifies the values for force and distance but struggles with calculating cos(30°) without a calculator, mistakenly believing it to be 1/2. Participants clarify that the cosine of 30 degrees is actually √3/2, which is essential for arriving at the correct work value of 836 J. The conversation highlights the importance of understanding trigonometric values, especially for special right triangles, and the user expresses a desire to learn how to compute these values without a calculator. Overall, the thread emphasizes the need for a solid grasp of algebra and trigonometry in physics problems.
peacerosetx
Greetings all :blushing:
Greetings all this is the basic type of problem that I am having. W = F d cos θ. This is not for homework this is for my preparation for an exam.
If you were pulling a box like in the example above, which moves 12.7 m when you pull
along the rope with a force of 76.0 N, determine how much work you did.
it has to do with the Work:: W = F d cos θ
I have the answer which is given as:
W = F d cos θ
= 76.0 N (12.7 m) cos30.0°
W = 836 J
The problem is that I do not know how to multiply cos30.0 to know how you get 836 J
I have tried to turn it into .5 so that it would be = 76.0 N(12.7m) (.5) but when I multiply it all together I get 482 and not 836 J
Can you please help me figure this out is it the way I am doing the algebra that is not correct or my conversion of the cos 30? Thank you
Welcome to PF.
The cosine of 30 degrees is NOT 1/2. That's why you didn't get the right answer. Generally speaking, All you're expected to do is to use a calculator to figure out what cos(30o) is.
cepheid said:
Welcome to PF.
Yes but for this exam that I will take I am not allowed to use a calculator. And I really would like to know how to use cosine and multiply with it not only for this but for other things as well. Do you know how to get to get to836 J without a calculator, or is it too hard to compute without a calculator please? Thank you. The examples seem to feel that we can do it on a scratch piece of paper. Thank you for your response
The sine and cosine of 30° (π/6 radians) and 60° (π/3 radians) are supposed to be easy to remember or derive because in this situation you have a special right triangle known as a 30°-60°-90° right triangle:
http://en.wikipedia.org/wiki/Special_right_triangles#30-60-90_triangle
By the way, your algebra and method is fine. You just had the wrong numbers.
Thank you for the information and the welcome I am still confused as to how to solve the equation. I will work on it some more though. God bless
Then how did you multiply (76.0 N) * (12.7 m)? I guess you could have done it by hand, but I don't think a physics exam that doesn't allow calculators would ask you to do that.
