Was the Car Speeding Based on Skid Mark Analysis?
The discussion focuses on determining whether a car was speeding based on skid mark analysis after an accident. Given the car's mass of 1000 kg, a skid distance of 32 meters, and a coefficient of friction of 0.45, the deceleration can be calculated. The frictional force leads to a deceleration of approximately -4.41 m/s², allowing for the calculation of the initial velocity using kinematic equations. The resulting initial speed is around 17 m/s, which exceeds the 25 mph (11.3 m/s) speed limit. The conclusion is that the driver was indeed speeding.
Elo21
you are a crime scene specialists. a car in an accident had skidded to a stop and left tire tracks for 32 meters. The coefficient of sliding friction between the tires and road is .45, and the car's mass is 1000kg. Was the driver exceeding 25mph (11.3m/s) speed limit?
u= Force Friction / Normal Force
F net= m*a
I can't figure it out because i don't think i know all the formulas i need to know.
I tried but it is to much to write.
Welcome to pf.
You know the friction force acting to slow the car.
So you can either use F=ma to work out the acceleration and what initial speed it would need to take that distance to stop.
Or you know energy= force * distance, work out how much energy you lost to friction over that distance and what initial kinetic energy (and so speed) you must have had.
F net= m*a
The first objective is to determine the car's deceleration. After that, we use kinematics to calculate the car's initial velocity and compare it to the speed limit.
The frictional force acting against the car's motion can be written as:
F_f = u_kF_N
The normal force is mg, so the equation becomes:
F_f = u_kmg
We can reduce this equation to:
ma_f = u_kmg
where, after canceling the masses from both sides, we have:
a_f = u_kg
so
a_f = - 4.41 m/s^2
Now plug this into the kinematics equation:
v_f^2 = v_i^2 + 2a_fx
Final velocity is 0. Just solve for the initial velocity and you should get around 17 m/s. The driver was speeding.
thank you.
F_f = u_kF_N
F_f = u_kmg
ma_f = u_kmg
a_f = u_kg
so
a_f = - 4.41 m/s^2
Please do not do the OP's homework for them. That's not how the Homework Help forums work here at the PF.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
