Watching an aeroplane through a window
  • Thread starter Thread starter bill nye scienceguy!
    Window
The discussion explores calculating the absolute velocity of an airplane by measuring the time it takes for its image to travel across a window. It suggests using similar triangles to estimate the distance traveled by the plane, assuming the flight direction is parallel to the window. However, complications arise when the plane's trajectory is not parallel, requiring adjustments to the calculations. The conversation includes a formula for speed that incorporates window width, distance to the window, angle of flight, and measured time. The discussion concludes by noting that at certain angles, the calculated speed can become infinite, indicating limitations in the method.
As I was sitting at work the other day productively watching an aeroplane fly across the window I started to think of this problem.
If I measure the time it takes for the image of the plane to track across a known distance on the window I can quickly calculate a speed at which the image is travelling. Assuming I know the distance of the plane, how can I extrapolate its absolute velocity?
Is it as simple as using similar triangles to estimate the absolute distance that the plane has traveled in the measured time and calculating from that or do I need to get reference frames involved?
Obviously this approach assumes I can accurately estimate how far away a plane is...
Triangles should be enough.
If the flight direction is not parallel with the window, things may go a little more complicated.
I was assuming that the travel was parallel to the window, in which case my triangles method is good enough.
If it were going into or away from the window, how would I go about it? I used to be pretty hot at transforming between different coordinate systems in 2d solid mechanics but dynamics was never my strong suit.
Still a triangle, just you will need two distances - one for each side of the window.
If you have the following data:
W: window width,
h: the distance from the viewer to the window,
β: the angle between the flight direction and the window ( positive angle when it is getting away from and negative when its coming toward the window)
t: the measured time
L: the distance from the viewer to the plane when it first appears in the window frame,
then for the speed v, you would come up with the following expression:
v=\frac{4hWL}{t\sqrt{W^{2}+4h^{2}}}\frac{1}{4hcosβ-Wsinβ}
It can be seen that for some large angles, v becomes infinite. This is because the plane doesn't disappear from the one sides of the window.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
