Water Cooling System: Simple & Affordable Solution
A Tunisian mechanical engineering student seeks an affordable method to cool water from an outdoor pool before it reaches three compressors. The student is exploring both low-power and high-power cooling solutions, including cooling towers, spray bars, and chillers. They are looking for simple and cost-effective options to implement during their internship. Resources on evaporative cooling and chiller basics have been shared for further reading. The student expresses gratitude for the assistance and plans to return with more questions.
YasmineBS
Hey everyone :)
I am a Tunisian Mechanical engineer student, doing my first practical internship. I need to find a way to cool water, that isn't expensive.
I have 'ambient heat' water that comes from an outdoor pool, then it goes to 3 different compressors, in order to cool them, then that same water goes back to the outdoor pool... and so on. I need to have a system that cools the water before it's arrival to the compressors.
I don't really know from what to start, what to read. It needs to be simple and not expensive.Many thanks !
Thank you so much, I will be reading them.
And I will come back if I have more questions.
Really helpful :)
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
