Is It Dew or Guttation on Banana Plant Leaves?
  • Thread starter ritwik06
  • Tags
    Water
In summary, the conversation discusses the presence of water droplets on the margins of banana plant leaves and whether they are dew drops or the result of guttation. Guttation is the exudation of water from leaves due to root pressure, which can appear as a single large pendant drop at the tip of the leaf. This is different from dew, which forms through condensation from water vapor in the atmosphere. The drops on banana plant leaves are more likely the result of guttation, as they come from small porous structures called hydathodes.
ritwik06
580
Droplets of water may sometimes be seen on the margins of the leaves of a banana plant, growing in wet soil, in tthe mornings. Are these dew drops? Comment on you answer.
These can be either dew drops or water exuded by guttation. what do you think?
Here's a definition via Google.
The water exuded from leaves as a result of root pressure. Sometimes guttation is confused with dew, although the origin and appearance of the resulting drops are different. On grass, dew appears as many drops that cover the surface of the blade; dew forms by condensation from water vapor in the atmosphere. Guttation appears as a single large pendant drop at the tip of the blade; guttation forms by the extrusion of liquid water from the moist ground. ...
Hydathodes
on the margin of the leaf , there are small porous structures called HYDATHODES, during guttation , due to excess pressure, the water droplets come out of those HYDATHODES. they are not dew drops.
Related to Is It Dew or Guttation on Banana Plant Leaves?
1. What is guttation?
Guttation is the process by which plants release excess water from their leaves, either through openings called hydathodes or through pores in the leaf surface.
2. How is guttation different from transpiration?
Guttation and transpiration are both methods of water loss in plants, but they differ in the mechanism and location. Guttation occurs through specialized structures on the leaf surface, while transpiration occurs through stomata on the underside of the leaf.
3. What is the purpose of guttation?
Guttation helps regulate the water balance in plants by removing excess water, preventing it from accumulating in the plant and potentially causing damage. It also aids in nutrient transport and can provide some protection against pests and diseases.
4. What factors can affect the amount of water exuded by guttation?
The amount of water exuded by guttation can be affected by environmental factors such as temperature, humidity, and light intensity. It can also be influenced by the plant's water and nutrient status, as well as its species and age.
5. Is guttation harmful to plants?
Guttation is a natural and necessary process for plants and is not harmful. However, if excessive guttation occurs, it can be a sign of overwatering or a problem with the plant's root system. It is important to monitor guttation and make any necessary adjustments to ensure the plant's health.
  • General Discussion
