Water Mass Calculation for Vessel Under Different Conditions
The discussion focuses on calculating the mass of water in a 0.6 ft³ vessel under various pressure and temperature conditions. Participants debate the applicability of the ideal gas law, noting that water vapor does not behave ideally, especially at high temperatures and pressures. It is emphasized that for certain conditions, such as saturated vapor and liquid states, steam tables should be used instead of the ideal gas equation. Understanding the relationship between saturation temperature and pressure is crucial for accurate calculations. Familiarity with terms like saturated vapor, saturated liquid, and critical state is recommended for solving the problem effectively.
xzibition8612
Calculate the mass of water contained in a 0.6 ft^3 vessel under the following conditions:
a) 15 psia, 300 F
b) 100 psia, 500 F
c) 20 psia, 210 F
d) 60 psia, saturated vapor
e) 60 psia, saturated liquid
f) at the critical state
PV=mRT
I suppose the ideal gas equation is valid? Can someone explain to me why or why not?
Assuming it's valid, for a,b the temperature is above the saturation (boiling) temperature, so R would be the water gas constant? For c, d, e, and f, I don't know what values to plug in for R. Any help would be appreciated. Thanks.
I think you are to determine if the vessel contains watwr as a vapour, as a liquid, or some combination of both for the cases. Water vapour doesn't follow the ideal as law so I suspect you have to use your steam tables.
saturation temperature and saturation pressure go hand in hand, so your comment that for a, b the temperature is above saturation temperature is invalid ( the boiling temperature you are thinking of is valid for atmospheric pressure )
do you know what the terms saturated vapour, saturated liquid and critical state mean - you should familiarize yourself with these terms. ( Use wikepedia if you like, or your textbook should have them defined )
