Water Skin Effect in Plastic Pipe
The discussion focuses on calculating the skin effect of water in a plastic pipe with varying diameters and a length of 200 mm under a pressure of 15 bar. The skin effect relates to the friction stress between the fluid and the pipe wall, which alters the velocity profile of the flow. For laminar flow, the velocity profile becomes parabolic, while turbulent flow results in a more complex profile, with the transition occurring over 10 to 20 tube diameters. A 200 mm tube is considered short if the diameter is 10 to 20 mm, complicating the analysis of flow development. Accurate calculations require understanding the entrance length and using resources like the Moody chart for determining the friction factor for both flow types.
DeereAdam
I need to Calculate the Skin Effect of water in a tube of X Diameter or Surface Area... The length of the Flow in the pipe would be 200 mm. I know that is short but it matters in this instance. The pressure of the water would be around 15 bar. I will post the flow rate through the pipe as soon as possible. The Diameter of the tube will change so I am looking for a calculation that I can input the flow rate and diameter and output the force from skin effect. The pipe is very smooth something similar to pvc. thanks for the help
I think the OP is asking about friction stress between the fluid and the tube wall. Fluid enters a pipe with equal velocity across the pipe entrance. Friction between the fluid and pipe changes the velocity profile to parabolic if the flow is laminar, and to a more complex velocity profile if the flow is turbulent. That transition occurs over a length of (typically) 10 to 20 tube diameters. Or more, or less, depending.
A 200 mm long tube is a short tube if the tube diameter of 10 to 20 mm or more. The flow in the entire length of the tube will be in transition from the flat velocity profile at the entrance to the fully developed velocity profile. Search fluid flow entrance length for procedures and equations. Note that laminar and turbulent flow are handled differently.
If a 200 mm long tube is, say 2 mm diameter or less, the entrance length will be a small fraction of the tube length. Then it can be analyzed as if the entire length is fully developed flow with minor error. Search Moody chart for the friction factor, the equation, and how to use the equation. This chart works for both laminar and turbulent flow.
Tube diameter between these ranges are a challenge, mostly because of the difficulty in accurately calculating the entrance length. You need to calculate the entrance length. Friction in the entrance length and friction in the fully developed flow are calculated separately.
Likes gmax137 and anorlunda
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
