Inlet Water Temp vs Feeder Water Temp in a BWR
  • Thread starter Thread starter Luxdot
    Water
The inlet water temperature in a Boiling Water Reactor (BWR) can exceed the feeder water temperature due to the recirculation flow of water exiting the core. The feedwater, sourced from the turbine condensation process, is typically at a lower temperature than the core inlet. In a BWR, moisture is separated at the core exit and mixed with cooler feedwater from the balance of plant before being pumped back to the core inlet. This mixing process results in the observed temperature differences.
  • Understanding of BWR operation and thermodynamics
  • Knowledge of recirculation flow dynamics in nuclear reactors
  • Familiarity with moisture separation processes in BWRs
  • Basic principles of heat transfer in fluid systems
  • Research BWR recirculation flow and its impact on temperature profiles
  • Study the function and design of moisture separators and steam dryers in BWRs
  • Explore the role of feedwater heaters in thermal efficiency
  • Investigate the thermodynamic cycles involved in turbine condensation
Nuclear engineers, reactor operators, and thermal system analysts involved in the design and operation of Boiling Water Reactors.
Luxdot
TL;DR
Inlet water temp vs feeder water temp
How can the inlet water temp be higher than the one of the feeder water that is in the reactor tank of a BWR?
If you mean feeder temperature is feedwater temperature.
If you mean inlet temperature is measured as water enters the core.
Then you need to consider recirculation flow. Some of the water exiting the core is recirculated back to the inlet and mixed with feedwater. The mixture goes to the core inlet.
Luxdot said:
Summary:: Inlet water temp vs feeder water temp
The feedwater is the water returning from the balance of plant, i.e., from the turbine condensation and condenser following the low pressure turbine. The water is at a lower temperature than core inlet. In a BWR, moisture (at core exit temperature) is separated in 'moisture separators' or 'steam dryers', and that is sent to the annulus where it is mixed with the cooler 'feedwater' from the balance of plant. The mixture is then pumped back to the core inlet.
https://en.wikipedia.org/wiki/Boiling_water_reactor#Condensate_and_feedwater
https://en.wikipedia.org/wiki/Feedwater_heater
  • · Replies 25 ·
  • · Replies 66 ·
  • · Replies 53 ·
  • · Replies 26 ·
