Investigating Wave Speed in Water: Uncovering the Theory
Wave speed in water increases with depth due to reduced interaction with the bottom surface, which minimizes friction and energy loss. This phenomenon is influenced by Stoke's Law, where viscosity plays a role in wave propagation. In shallower water, waves encounter more barriers, leading to slower speeds as energy is dissipated. The concept of laminar flow is relevant, as it describes how water moves in layers, affecting wave behavior. Understanding these principles can clarify the relationship between water depth and wave speed.
Amber
I'm doing an investigation on how the speed of a wave varies as the depth of water changes, using a tray of water. I know that in deeper water the speed will be quicker than that in shallow water. However I don't quite understand why this is. Apparently it has something to do with Stoke's Law? Is it related to the viscosity and the flow of water in different conditions - the more volume there is, the faster it will travel? Please help me with the theory behind it to help me understand better.
Thank you,
- Amber
Try to think of the problem along this line, a ball is traveling along a frictionless surface at a constant speed, but when it start traveling uphill, its speed decreases because the kinetic energy of the ball is being converted into gravitational potential energy.
So, what would happen to a water wave when it encounters a barrier?
Thank you.
When the water waves encounter a barrier, it will slow down - so the less water there is, the more "barriers" are in contact. Therefore in shallower water the speed is slower? Is that correct?
It would help if the teacher taught us properly instead of asking us to read the textbook, and I find that doesn't help much.
Now I need to know how laminar flow relates to all this :confused:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
