Converting a Longitudinal Wave Displacement-Time Graph into a Distance Graph
  • Thread starter Thread starter yipkawa
    Graph Wave
To convert a longitudinal wave displacement-time graph into a displacement-distance graph, the wave equation y(x,t) = Asin(2π/λ x - ωt) is used. By keeping time (t) constant, y can be plotted as a function of distance (x). This allows for a clear representation of wave displacement over distance. The process simplifies the analysis of wave behavior in a spatial context. Understanding this transformation is essential for studying wave properties effectively.
yipkawa
how to turn a 'longitudinal wave ' displacement-time graph into a displacement-distance graph
The solution for a traveling wave is:
y(x,t) = Asin(\frac{2\pi}{\lambda}x - \omega t)
To turn it into a displacement distance graph, just plot y as a function of x, keeping t constant.
AM
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
