Weight of 7 ft Water Column w/ Radius 1.1m
The weight of a 7 ft high water column with a radius of 1.1 m is calculated using the formula Weight = Volume * Density. The volume is determined to be 8.1064 m³, leading to a mass of 8106.39984 kg. To convert mass to weight in Newtons, multiply by the acceleration due to gravity (g = 9.81 m/s²). Thus, the final weight is approximately 79,500.5 N.
  • Understanding of fluid density (1000 kg/m³ for water)
  • Knowledge of volume calculation for cylinders (Volume = π * r² * h)
  • Familiarity with unit conversion between mass and weight
  • Basic physics concepts, specifically Newton's second law (Weight = Mass * g)
  • Research the effects of varying water density on weight calculations
  • Learn about the implications of using different values for gravitational acceleration (g)
  • Explore the calculation of weight for other fluids with different densities
  • Study the application of these principles in engineering and fluid mechanics
Students in physics or engineering courses, educators teaching fluid mechanics, and professionals involved in hydraulic calculations or water resource management.
missashley
What is the weight of a column of water 7 ft high with a radius of 1.1m?
The density of the water is 1000 kg/m/m/m
Answer in units of N.
Volume = pi * r^2 * h
7 ft = 2.1336 m
Volume = 3.14 * 1.1^2 * 2.1336 = 8.1064 m^3
Weight = 8.1064 m^3 * 1000 kg/m^3
Weight = 8106.39984 kg
1 Newton = kg * m/s2
i'm stuck here
Your formula is not quite right.
It should be: Mass = Volume * Density
Mass is expressed in kilograms.
The weight of an object is equal to its mass multiplied by g, where g is the acceleration due to gravity (9.81 m/s^2). Weight is expressed in Newtons.
As stated above, take this as mass and multiply it by gravity, which will either be 9.81 or 10 depending on your level.
  • · Replies 63 ·
