Weighted averages in groups with common range
  • Context: Undergrad
  • Thread starter Thread starter td3201
    Groups Range
The discussion revolves around the challenge of calculating weighted averages for survey questions grouped into categories, ensuring that the averages across categories and the overall average maintain a consistent range. The context includes theoretical considerations and practical applications of data manipulation in Excel.
  • One participant describes a scenario involving survey questions with weights, aiming to achieve a consistent range for category averages and an overall average.
  • Another participant suggests equalizing all weights in a category to 1 (100%) as a potential solution.
  • A different participant proposes an affine mapping approach to adjust scores from different categories to a common range, detailing the transformation formula.
  • Concerns are raised about the scalability of the proposed solution when changing the range of scores.
  • A participant reflects on the importance of capturing raw data to allow for recalculations if the range changes, indicating a shift in their initial concern regarding score quality.
Participants express varying ideas on how to handle the weighting and scoring system, with no consensus reached on a single method. Some approaches are proposed, but concerns about scalability and consistency remain unresolved.
Participants note the potential limitations of their approaches, including the dependence on the specific ranges used and the implications of changing those ranges on score quality.
This discussion may be useful for individuals interested in data analysis, survey methodology, or those working with weighted averages in statistical contexts.
td3201
I am doing a survey of questions grouped into categories. Each question has a weight applied to it. I want to then total and average each category. Lastly, I want to total and average all the categories together. Here's the challenge: I want all of categories and the total average to have the same range somehow.
See attachment (png file) for a pic of the data I mocked up to describe my situation.
The answers are a range of 1-5 (likert scale). So as you can see in the picture, the group ranges are 1-5, 1.45-7.25, and 1.90-9.50 respectively. However, the group is a completely different range 1.45-7.25. This is naturally happening because of the different weights on the questions. My end goal here is to give an average score for each category and the total score at the end similar to a FICO score. So the ranges must be the same for them to have the same effect. How can I do this with these weights in the mix?
I just had a thought. Would it work if I made all of the weights in the category equal 1 (100%)?
Scratch that, not it.
Suppose the actual scores are Xa (total in category A), Xb, Xc. You still want the total score to be Xa+Xb+Xc (or dividing by total number of questions if you want the average), right? But you also want to quote average scores by category in a way that's consistent with the overall average.
If the overall range is Y to Z, and the range for category A is Ya to Za, apply an affine mapping to the score Sa on category A: Sa->(Sa-Ya)*(Z-Y)/(Za-Ya) + Y. This maps Ya to Y, Za to Z, and everything in between in proportion.
This seems to work pretty well. However, it does not seem to scale if I change the range. Is there a way to make the "grade" the same based on the range?
Range = 1000-200
CategoryA Score = 504.2
Percentage Grade = 59.9%
Range = 850-300
CategoryA Score = 509.14
Percentage Grade = 50.4%
Excel formula
=((AVERAGE(J6:J16)-D17)*($B$1-$B$2)/(E17-D17)+$B$2)
504.20=(2.7273-1.0667)*(1000-200)/(5.4091-1.0667)+200
509.14=(2.7273-1.0667)*(850-300)/(5.4091-1.0667)+300
Entry Weight Score
1 1.2 1.2
2 1.3 2.6
3 1 3
4 1 4
5 1 5
1 1 1
2 1.1 2.2
3 1 3
4 1.2 4.8
1 1 1
2 1.1 2.2
I think I talked myself out of my concern. The reason I was concerned is if we ever change the range, it would mess with the quality of the scores. However, we are capturing the raw (non-weighted) data so we can re-calculate as needed. This is a very low possibility but fun to project either way. Your solution worked. This kind of reminds me of a bit field:
http://en.wikipedia.org/wiki/Bit_field
Thanks!
  • · Replies 25 ·
