A Weird problem with a Lagrangian
  • A
  • Thread starter Thread starter ShayanJ
    Lagrangian Weird
ShayanJ
Insights Author
I'm trying to follow the calculations in this paper. But I have a weird problem in section 2.
To calculate the entanglement entropy using the Ryu-Takayanagi prescription, you have to extremize the area of a surface. So you have to use Euler-Lagrange equations for some kind of an action. The authors don't do all the calculations and just point out that the result is eq. 13.
But when I do the calculations I get something else. Actually eq. 13 doesn't even satisfy the Euler-Lagrange equation of the action but my solution does. So it makes me think that I may have done something wrong in getting the equations of motion but I'm pretty sure about my calculations, I've done and checked them more than a dozen times!
So I just have no idea what is wrong here. My calculations are attached.(Sorry if I don't write them here, but I made this pdf for my advisor so I just attach it here!)
Thanks
P.S.
I also think that in eq.10, the power of ##\alpha## should be 2 instead of d. But its irrelevant here because ##H(U)## is just assumed to be some known function.
Likes Kninfinite
Another weird thing that I just realized. If you put ##U_x=\sqrt{-\frac 1 \beta}## in the action, you get zero!
EDIT: Or maybe there is nothing wrong with it. The on-shell value of the action can be anything and now its zero.
Toponium is a hadron which is the bound state of a valance top quark and a valance antitop quark. Oversimplified presentations often state that top quarks don't form hadrons, because they decay to bottom quarks extremely rapidly after they are created, leaving no time to form a hadron. And, the vast majority of the time, this is true. But, the lifetime of a top quark is only an average lifetime. Sometimes it decays faster and sometimes it decays slower. In the highly improbable case that...
I'm following this paper by Kitaev on SL(2,R) representations and I'm having a problem in the normalization of the continuous eigenfunctions (eqs. (67)-(70)), which satisfy \langle f_s | f_{s'} \rangle = \int_{0}^{1} \frac{2}{(1-u)^2} f_s(u)^* f_{s'}(u) \, du. \tag{67} The singular contribution of the integral arises at the endpoint u=1 of the integral, and in the limit u \to 1, the function f_s(u) takes on the form f_s(u) \approx a_s (1-u)^{1/2 + i s} + a_s^* (1-u)^{1/2 - i s}. \tag{70}...
