Welcome to the Engineers Forum! Share Knowledge & Experiences Here
The forum welcomes engineers to share knowledge and experiences, fostering a supportive community. A mechanical engineering student from Iraq is seeking assistance with a graduation project focused on gears, specifically using Ansys 5.4 software to analyze stress concentration. He expresses gratitude for shared links and resources, although he still requires tutorials for applying theoretical concepts in the software. The discussion highlights the challenge of accessing free academic papers on the topic, suggesting that many resources are behind paywalls. Overall, the forum serves as a valuable platform for collaboration and knowledge exchange among engineering professionals.
mech.eng.
Hi everyone
this is a fantastic forum ,I have browsed through the threads and found it fantastic to
such a community for engineers to share knowledge ,experience and advice. It will boost
the mutual interests of members ,so consequently I registered today and I would like
you to accept me as a friend.
I'm a mechanical engineer from Iraq ,mechanics is my ultimate passion specially when it
comes for designing machines ,and all kinds of vehicles .This is my last undergraduate
year and I'm supposed to graduate in a few months ,after gud bless .
I have a graduation project which is about gears and I'm conducting most of the work
via Ansys 5.4 software by which I'm trying to draw a gear ,assign a load on one of it's
teeth and get a graph which illustrates the regions of stress concentration,so if anyone
has a tutorial articles or program concerning this particular subject and can help I would
be very grateful.
The majority of papers I have seen on the topic are not available for free. Usually you have to purchase them from organizations like AGMA. I would suggest looking through their publications. You will find pretty much anything you are ever going to need.
For starters:
http://courses.washington.edu/mengr356/daly/Gear_stress.pdf
Here are a couple of links, but they're not entirely helpful for what you're doing.
http://www.public.asu.edu/~smurshed/academic/publications/4thimec.pdf
http://www.mech.uwa.edu.au/DANotes/gears/failure/failure.html
Thank you FredGarvin the links you've listed are truly beneficial ,It will do me good on
the theoritical part of my project.but I still need apply these theories on a computer software i.e. (ansys 5.40) and I need some tutorials to help me deal with that programs
specially the method of drawing gear's teeth.thank you very much again and I appreciate that significant help.
Here are a couple of tutorials referencing Pro-E for doing involute gear forms. While it is not ANSYS, you should be able to glean a lot of how to information from them.
EDIT: Crud. One of my pdf files is above the limit for file size. Let me see if I can reduce its size.
thank you very much FredGarvin ,I'm very content of this pdf file .
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
