Can a Transformer Be Converted into a Welder Transformer?
  • Electrical
  • Thread starter Redio
  • Tags
    Transformer
In summary, Mr radio needs to convert his transformer to make a welder. He has both practical and theoretical experience with welding, so he asks the OP for advice on how to do this. He also puts a bridger rectifier and 2 condesators in order to increase the voltage going into the transformer. He then asks the OP for a connection diagram.
Redio
Hello can anyone how to convert this transformer in a welder transformer
Convert it to what?
Likes jim hardy
In a welder transformer
Hello Mr radio
That's ok, well explanation about what do to use it?
I need this transformer to make a welder the input voltage is 220v and the output is 108v and58 v but in 58 volt is has no amperage
May I ask what experience you have with electronics because creating a welder with a transformer can be quite dangerous. I haven’t done it but I have learned about the danger when I wanted to make one.
I finished the welder but i have somme issues on the input voltage is to hight is 143 volt
I have both practical and theoretical experience on welder stuff.. So I need to ask you some question about your present transformer
Thnx .my transformet is 220v input and 140 v out pu
I have also putet a bridger rectifier
And 2 condesatorss 4700uf 450 volt
On the contrary your transformer is 220/110 step down/step up. It has 4 block of coils.. Each with voltage rate of approximately 55V ... Therefore with this parameters you can only have secondary output of minimum 73V.. By taking 3 block and put them in series and also isolating the 4th coil connection to be the secondary... You will have 220V input 73V output and probably 20-30% duty cycle.. What can u weld with this high voltage of 73V care must be taking operating with such high voltage.. And remember the current might be lower than expected.. You can increase that by changing the secondary winding with a 2X size of the original coil and half the turns then you will get 2* your current and the voltage drod to half.(31.5V) thanks
Likes Spinnor
Thnx for the advice
Likes Adiel Samson
This is look like
I hawe 145dc in output is possible to put a rheostat to lower the dc to +/- 50 volt
Or more
Please make your connection like this
Ok thnx
Likes Adiel Samson
Much beter now 75 volt an 80volt on the other core thnx
Likes Adiel Samson
Thanks for understanding my guide
Likes Redio
The OP question has been well answered. Thread closed.
1. What is a welder transformer and how does it work?
A welder transformer is a device that converts high voltage, low current electricity into low voltage, high current electricity. This is necessary for welding because it allows for a more stable and controllable arc between the welding electrode and the metal being welded.
2. What are the common issues with welder transformers?
The most common issue with welder transformers is overheating, which can be caused by overloading the transformer or using it for extended periods of time without proper cooling. Other issues include short circuits, damaged insulation, and loose connections.
3. How can I troubleshoot a welder transformer issue?
If you suspect a problem with your welder transformer, you should first check for any loose connections or damaged insulation. You can also use a multimeter to test the transformer for continuity and proper voltage output. If the issue persists, it is best to consult a professional for further troubleshooting and repairs.
4. Can a welder transformer be repaired?
In most cases, a welder transformer can be repaired if the issue is minor. This may involve replacing damaged parts or re-winding the transformer coils. However, if the transformer is severely damaged or the cost of repairs is too high, it may be more cost-effective to replace the transformer altogether.
5. How can I prevent issues with my welder transformer?
To prevent issues with your welder transformer, it is important to follow proper usage and maintenance guidelines. This includes not overloading the transformer, allowing it to cool down between uses, and regularly cleaning and inspecting it for any damage. It is also important to use the correct voltage and amperage settings for your specific welding project.
  • Linear and Abstract Algebra
  • DIY Projects
  • Set Theory, Logic, Probability, Statistics
  • Electrical Engineering
