What Are Counterexamples for AεB and BεD Leading to AεD?
  • Thread starter Thread starter Wildcat
Wildcat
Find a counterexample for the following
If AεB and BεD, then AεD.
The answer given is let A={1} B={{1}} and D={{{1}}}
I have not seen this notation before and don't know what it means.
Can someone explain please??
Let's give a different (counter)example: (The highlighting is merely for emphasis.)
Let A={1, 2}
Let B={{1}, {3}, {1, 2}, {1, 2, 4, 8}} ---- You could also write this as: B={{1}, {3}, A, {1, 2, 4, 8}}
Let D={ {{1}, {3}}, {{1, 2, 3}, {1, 2, 4, 8}}, {{1}, {3}, {1, 2}, {1, 2, 4, 8}} }
A is a set whose elements are natural numbers: in this case 1 & 2.
B is a set whose elements are themselves sets: in this case sets of natural numbers, one of which is the set A.
D is a set whose elements are sets of sets. Although the set A is contained in one of the sets of sets, namely set B, which appear in set D, A itself does not appear as one of the elements of set D.
The (counter)example give as the solution is merely a very simple one.
Let A={1, 2}
Your counter example is much easier to understand. I still don't know about the one given. Is it saying in A 1 is a natural number, then B is the set {1} then D ugh I don't know? Can you explain that as simply as your counterexample?
They're saying:
A={1}
A is a set whose only element is the number, 1.​
B={ {1} }
B is a set whose only element is the set {1}. You can also say: B is a set whose only element is the set A, because A = {1}
D={ { {1} } }
D is a set whose only element is the set B, which is itself a set containing the set A.​
Yes, it can be somewhat confusing. The main idea here is the the number, 1, is not an element of either set B or set D. set B contains a set. That set contains the number 1.
SammyS said:
They're saying:
A={1}
B={ {1} }
D={ { {1} } }
Thank you sooo much! I still like your example better :)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
