What Are the Dimensions of a Wave Function in Various Box Problems?
The wave function does have dimensions, which vary depending on the dimensionality of the problem. For a 1D box, the wave function has dimensions of length^{-1/2}, while for a 2D box, it is length^{-1}. The generalization to n dimensions indicates that the wave function's dimensions are length^{(n-3)/2}. The modulus squared of the wave function represents a probability density, which confirms that the wave function itself cannot be dimensionless. This discussion clarifies the relationship between wave functions and their dimensions in quantum mechanics.
armis
Does the wave function have a dimension? If it does, what are the dimensions for 1D and 2D box problems?Can you generalise this to n dimensions?
Yes, it does have dimensions. For 1D box it's m^{-2} , for 2D box it's m^{-1} thus for n dimensions it should be m^{n-3} . Is this correct?<br /> <br /> thanks
I think it has no dimensions. p(r) = |\psi|^2 is the density of the probability of finding a practical in a specific location.
But maybe I'm wrong
a wave function inside a 1 dim box is
\Psi= \sqrt{\frac{2}{L}}sin(\frac{px}{\hbar})
it appears it is per root meter, which is weird. but on the other hand, the probability in the interval dx is:
|\Psi|^{2} dx = \frac{1}{\sqrt{meter}}^{2}*meter = 1
which would make it dimensionless, which could make sense. I've never asked myself this.
It's not dimensionless. If it were, then when you integrated its square modulus over all space you would not get a pure number. (Note to the second poster - the modulus squared of the wavefunction is not a probability, but a probability density, which had dimensions.). That is, since
\int_{\rm all space} d\mathbf{r} \left|\psi(\mathbf{r})\right|^2 = 1
\psi(\mathbf{r}) must accordingly have the root of the inverse dimensions of d\mathbf{r}, which are length^{-1/2} for a 1D problem (d\mathbf{r} = dx), length^{-1} for a 2D problem (d\mathbf{r} = dxdy), etc.
So, the original poster is correct about the wave functions having dimensions, but you got the dimensions incorrect.
I stand corrected. although I did say |psy|^2 is the density of probability.
Oh, I see. Thanks
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
