What are the equations to calculate friction
  • Thread starter Thread starter ellomoto135
    Friction
Friction can be calculated using different equations depending on the state of motion of the surfaces involved. For stationary surfaces, the friction force is part of the reaction force. When surfaces are moving, the friction force is determined by the kinetic coefficient of friction (µk) multiplied by the normal force (N). If the surfaces are about to move, the static coefficient of friction (µs) is used instead, also multiplied by the normal force. Understanding these coefficients is essential for accurate friction calculations.
ellomoto135
What are the equations that can be used to calculate friction, be detailed i don't know much about.
welcome to pf!
hi ellomoto135! welcome to pf! :smile:
there isn't much to say …
if the surfaces aren't moving, and aren't "about to move", the friction force is simply part of the reaction force … you calculate it exactly as if the surfaces were fixed together
if they are moving, you have to look up the kinetic (dynamic) coefficient of friction, µk, in a table (or it'll be given in an exam question), and then
the friction force is µkN (where N is the normal force)
if they are "about to move", you have to look up the static coefficient of friction, µs, in a table (or it'll be given in an exam question), and then
the friction force is µsN (where N is the normal force) :wink:
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
