Mo
- 81
...a torch bulb, LED, small motor, buzzer, mains lamp, electric kettle? (in normal operation)
Regards
Mo
Regards
Mo
The typical values of current through a system can be influenced by various factors such as the resistance of the system, the voltage applied, the type of conductors used, and the temperature of the system.
Current is typically measured using a device called an ammeter, which is connected in series with the circuit to measure the flow of electrons through a specific point in the system.
The unit of measurement for current is the ampere (A), which is defined as the flow of one coulomb of charge per second.
In household circuits, the typical values of current can range from 10-20 amps for smaller appliances and electronics, up to 100-200 amps for larger appliances such as refrigerators or air conditioners.
The current through a system can be controlled by varying the resistance in the circuit, adjusting the voltage applied, or using devices such as resistors or diodes to regulate the flow of electrons.
