What are the units of Kp, (Gas phase equilibrium)
Equilibrium constants Kc and Kp are often misunderstood regarding their units. Kc is typically expressed in mol/L, while Kp can be expressed in atm or mol/atm, depending on the reaction. However, all equilibrium constants should ideally be dimensionless, as they are defined in terms of activities rather than concentrations or pressures. Activities are calculated using the formula aA = γA[A], where aA is the activity, γA is the activity coefficient, and [A] is the concentration or partial pressure. In dilute solutions, the activity coefficient is approximately 1, but it varies with concentration. It is crucial to note that having units for K can complicate calculations, especially when taking logarithms, as in the equation ΔG = RTln(K). The relationship between Kp and Kc is also highlighted, indicating that their values can be equivalent under certain conditions.
AMan24
I know the units of Kc are mol/liter. The units of Kp are either mol/atm or just atm. Not really sure. I get mles atm and liters in my answer when i solve. Pretty weird
Chemistry news on Phys.org
Actually Kp (and Kc) have no units.
Note, that you will get different units for different reactions, depending on the set of coefficients used. Try
2A ↔ B
A ↔ B
and
A ↔ 2B
and you will see what I mean.
That's when you try to express K using pressures or concentrations, but - what is often omitted in an approximate treatment used when teaching beginners - K is expressed using activities. As a first approximation activity is equal to the concentration (or pressure), but it can differ. We express it with
aA = γA[A]
where aA is activity of A, γA is its activity coefficient (with units chosen so that the activity becomes unitles) and [A] is the A concentration (but it could be pA, partial pressure of A, as well). For diluted solutions γ equals 1, but the higher the concentration, the more it can differ.
Also note that having units on K is a sure way of getting into problems. In thermodynamics we often need to calculate log of K (as in ΔG=RTln(K)) , good luck doing that when K is not unitles.
Edit: beaten by DrClaude.
Likes MexChemE, Chestermiller and AMan24
When is Kp = Kc?
18K
