What are the Unknown EMF and Currents in this Kirchhoff's Circuit?
  • Thread starter Thread starter Bob Loblaw
    Circuit Laws
The discussion focuses on solving for unknown electromotive force (emf) and currents in a Kirchhoff's circuit with a resistor value of 3.48 ohms. The user has set up equations based on Kirchhoff's laws but is struggling to find the correct values for the currents and emf. They have outlined their equations for both the left and outside loops, applying the junction rule at a central junction. Despite their calculations, they believe their current value for I1 is incorrect and are seeking assistance in identifying their error. The conversation highlights the importance of accurately applying circuit laws to solve for unknowns in electrical circuits.
Bob Loblaw
http://img207.imageshack.us/img207/1685/p1854altco4.gif
Find the unknown emf and the unknown currents in the circuit below, in which R = 3.48 . Take the positive direction for current flow in each branch to be upwards.
EMF = V
left branch= A
right branch= A
Kirchhoff's circuit laws
I added current lines to the diagram. Note that a coordinate system is imposed and all positive charges point up ( I guess this makes grading easier). I sketched the lines of current as best I could.
Here are my equations:
Left loop:
1.00v-3.48I1-E+(.05*2)
Outside loop:
1.00v-3.48I1-1.00I3+1.20V+4.00I3=0 (edit: caught a mistake here, last term should have been positive)
Apply junction rule to top center junction:
I1+.05=I3
Combine terms:
1.00v-3.48I1-E+.1=0
2.20v-3.48I1+3.00I3=0
Substituting I1+.05 for I3:
2.20v-3.48I1+3.00I1+.15=0
Combining like terms:
2.35-.48I1=0
I1(the left loop)=4.90A which is wrong.
Any ideas where I messed up?
Where is the circuit diagram?
Blast from the past! I have since moved past physics and on to medicine so things worked out well enough I suppose.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
