What causes minor calibrations for wrenches
  • Thread starter Thread starter stan
    Minor
Minor calibration of torque wrenches is necessary to maintain accuracy and reliability over time, as all measurement devices require periodic checks. Calibration drift can occur due to normal wear and tear, especially when the wrench is frequently used near its upper limit. While drift is typically not significant in most applications, routine calibration serves as a quality assurance measure. Ensuring tools remain within their specified range is crucial for effective performance. Regular calibration helps prevent inaccuracies that could affect outcomes in manufacturing and other applications.
stan
hi all
any idea why minor calibration is needed for torque wrenches?
what causes the wrench to be out of range in the first place?
stan
stan said:
hi all
stan
It is customary in manufacturing to calibrate all measurement devices and the measuring or control systems of tools. This is ensure that the measuring devices and tools are accurate and reliable over time.
Drift in calibration may occur with usage, i.e. normal 'wear and tear'. In the case of a torque wrench, if one frequently uses the wrench at the upper limit of its range, one is more likely to find drift in calibration. Probably in most applications though, drift is not significant, and the routine calibration test is more for quality assurance.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
