What causes the random decay of atoms in different interpretations?
The discussion centers on the interpretation of atomic decay within quantum mechanics, specifically contrasting Standard Quantum Mechanics (QM) with Bohmian Quantum Mechanics (BQM). Standard QM posits that decay times are probabilistic and not predetermined, while BQM aims for a deterministic framework but struggles with defining decay time. The conversation highlights that the ambiguity surrounding time in QM affects both interpretations, suggesting a need for a unified approach that treats time as a dimension akin to space. This approach allows for deriving decay probabilities from first principles, aligning statistical predictions with those of Standard QM.
  • Understanding of Standard Quantum Mechanics (QM)
  • Familiarity with Bohmian Quantum Mechanics (BQM)
  • Knowledge of Hilbert space and quantum observables
  • Concept of relativistic time as a hidden variable
  • Research the implications of time as a fourth dimension in quantum mechanics
  • Explore the role of hidden variables in Bohmian Quantum Mechanics
  • Study the concept of decoherence in quantum field theory
  • Examine the papers referenced for detailed methodologies in both Standard and Bohmian QM
Physicists, quantum mechanics researchers, and students interested in the philosophical implications of atomic decay and the interpretations of quantum theory.
Fyzix
What causes the "random" decay of atoms in different interpretations?
I'd like proponents of each interpretation to explain what their interpretation says about this issue?
What happens/causes radio active decay?
I know that atleast dBB and MWI needs to have a deterministic answer to this, so what is it?
Interesting question, but let me first slightly reformulate it into a more precise form:
What determines time at which an unstable atom will decay?
Standard QM says that nothing determines it, i.e. that only probability for a decay at given time is determined. By contrast, Bohmian QM should give a deterministic answer. But what that deterministic Bohmian answer is?
Admittedly, Bohmian QM cannot easily answer that question. But is it a problem of Bohmian QM? My answer is - no. More precisely, my claim is that it is not a problem of Bohmian QM per se, but actually a problem of standard QM that reflects in Bohmian QM as well.
Let me explain. In Bohmian QM there is a general theorem saying that Bohmian QM makes the same measurable statistical predictions as standard QM whenever the predictions of standard QM are unambiguous. Indeed, in standard QM, the probability distribution is unambiguous for any observable (such as position, momentum, energy, spin, etc.) given by an operator in the Hilbert space. But the problem is that time in QM is not an operator. Or at least, the time operator in QM is not unambiguously defined. The issue of time in QM is a controversial subject even within standard QM. There are several proposals for the solution of it, but none of them is a "standard" one.
So, without an unambiguous probabilistic description of decay time in standard QM, one shouldn't expect an unambiguous answer in Bohmian QM. Instead, it seems reasonable to choose one specific (even if not generally accepted) approach in standard QM and then explore the Bohmian variant of it as well. This is what I will do in the next post ...
... So let me briefly explain one approach (in both standard and Bohmian QM) that seems most promissing to me. An interested reader can find more details in
http://xxx.lanl.gov/abs/0811.1905 [Int. J. Quantum Inf. 7 (2009) 595-602]
http://xxx.lanl.gov/abs/1002.3226 [Int. J. Quantum Inf. 9 (2011) 367-377]
The essence of this approach is to treat time on an equal footing with space. Space is treated as in the standard approach, while time is treated just as one additional (fourth) dimension. This approach is relativistic in spirit, but a non-relativistic limit of it is also different from the usual treatment of time in QM. In fact, it can be thought of as a generalization of usual QM, in the sense that wave functions now live in an extended Hilbert space - a space of functions of both x and t.
With this approach, the usual rules of thumb on decay probabilities in standard QM now can be derived from first principles, just as for any other quantum observable. But how the Bohmian deterministic approach determines time at which the decay will happen? As usual in Bohmian QM, it all depends on the initial particle positions. However, now the "initial position" has a somewhat different meaning. While in the usual Bohmian QM the initial position is the set
x(t=0), y(t=0), z(t=0),
which clearly does not treat time on an equal footing with space, in the approach I am talking about the initial condition is the set
x(s=0), y(s=0), z(s=0), t(s=0)
where s is a relativistic-scalar parameter that parameterizes the trajectory. This parameter can be thought of as a generalized proper time. In this approach time t is also one of the hidden variables that may not be known in advance, which in essence is why the time of an event (such as a decay) looks random. As discussed in more detail in the papers above, the final statistical predictions coincide with those of standard QM.
In the two posts above, I was concentrated on the issue of TIME at which the decay happens. But there is also another use particularly relevant for Bohmian mechanics. If the decay involves a creation of NEW particles (e.g. photons), how can it be compatible with continuous particle trajectories in Bohmian mechanics?
Since a creation of particles is involved, it must be related to Bohmian interpretation of quantum field theory. Again, there are several different approaches, but according to my favored one
http://xxx.lanl.gov/abs/0904.2287 [Int. J. Mod. Phys. A25:1477-1505, 2010]
particle creation and destruction is only an illusion, created by decoherence caused by interaction with particle detectors.
Based on the thermal interpretation, I developed a quantum version of the classical, mechanical universe suggested by Laplace over 200 years ago. Abstract. The purpose of this paper is to propose a quantum version of the classical, mechanical universe suggested by Laplace over 200 years ago. The proposed theory operates fully within the established mathematical formalism of quantum field theory. The proposed theory unifies the classical and quantum intuition about the macroscopic and...
  • · Replies 62 ·
  • · Replies 21 ·
  • · Replies 76 ·
  • · Replies 35 ·
  • · Replies 38 ·
  • · Replies 292 ·
13K
