What cuvette to use for fast vaporizing liquids?
  • Thread starter Thread starter surepic
    Liquids
For fast vaporizing liquids at room temperature, Teflon stoppers in cuvettes are currently being used, but they struggle to maintain a proper seal at temperatures above 15 degrees Celsius, leading to vapor escape. Alternatives such as Viton and urethane are suggested for stoppers due to their chemical resistance and better sealing properties. Viton is particularly noted for its effectiveness with aviation kerosene, while urethane offers a better grip. The discussion also raises the possibility of using parafilm to wrap the cuvette top as a temporary solution to prevent vapor loss.
surepic
What type of cuvettes are you using for fast vaporizing liquids at room temperature ?
I found that cuvettes with Teflon stoppers are working so far but the problem is that at room temperature stopper to cuvette wall seal is not enough to hold that pressure so above 15degrees C vapours are finding their way out. I can't use stoppers with holes because of vapours (concentration in the sample is dropping).
Sample is aviation kerosene.
Chemistry news on Phys.org
Consider "Viton" or a urethane for a stopper material. Viton is used in carburetor float valves because it is impervious to both gasoline and alcohol. I mentioned urethane because it is 'grippyer'. Here is a link for chemical resistance of various polymers.
http://www.mossrubber.com/pdfs/Chem_Res.pdf
How long does the stuff in the cuvette have to last? Can you just wrap the top in parafilm and be done with it?
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
