What Determines the Angle of a Complex Number in Polar Form?
The angle of a complex number in polar form is determined by the arctan function, specifically arctan(b/a), where 'b' is the imaginary component and 'a' is the real component. For the complex number defined as cn = sin(nπ/2)/(nπ), the angle is π for n = 3, 7, 11, and 0 for all other values of n. The discussion highlights that for even n, cn equals 0, resulting in an angle of 0 degrees. The peculiarities of complex numbers, particularly regarding their angles and the implications for functions like logarithms and square roots, are also addressed.
  • Understanding of complex numbers and their polar representation
  • Familiarity with the arctan function and its application in determining angles
  • Knowledge of Euler's formula: e^{iθ} = cos(θ) + jsin(θ)
  • Basic concepts of continuity and discontinuity in mathematical functions
  • Study the properties of complex numbers in polar form
  • Learn about the implications of discontinuities in complex logarithmic functions
  • Explore the half-angle formulas in trigonometry and their relation to complex numbers
  • Investigate the periodic nature of the exponential function in complex analysis
Mathematicians, physics students, and anyone interested in complex analysis, particularly those exploring the properties and applications of complex numbers in polar form.
carlodelmundo
Hi all.
Suppose I am looking for the following quantity: [itex]\sphericalangle[/itex] cn, where cn = [itex]\frac{sin(\frac{nπ}{2})}{nπ}[/itex]. cn is a complex number.
According to the book, "Signals and Systems" by Edward Kamen 2nd. Ed., [itex]\sphericalangle[/itex] cn = π for n = 3, 7, 11 ... , and cn = 0, for all other n.
The angle of a complex number is defined by arctan(b/a), where b is the imaginary component of the complex number, and a is the real component. In this case, there is no imaginary component (b).
Using the Euler Formula: e[itex]^{iθ}[/itex] = cos (θ) + jsin(θ), I can derive the relation of sin(θ) to an exponential, but I feel this is going backwards.
Any hints/insights is appreciated.
I figured it out. This is a complex number with only a real part. e.g.:
For even n, note that cn is equal to 0. The angle of a zero complex number is 0.
For n = 1, 5, 9, ..., c = a + bj, a is 1, b is 0. arctan(0/1) is 0 degrees.
For n = 3, 7, 11, ..., c = a + bj, a is -1, b is 0. 180 - arctan(0/1) is 180 degrees.
indeed, with complex numbers, the end-points of the unit semi-circle lie on the real axis. one feels intutively, that real numbers should correspond to "angle 0".
but if one regards a complex number in polar form, then the radius (norm, modulus) is positive, so to get the negative real numbers we need a non-zero angle (pi).
this peculiarity of the complex numbers, messes up things like the logarithm function and the square root function. for example, a square root should be a "half-angle formula".
but if our angle is near 2pi, our angle is also near 0, and we're going to have a "jump" (discontinuity) when taking square roots.
so complex numbers solve one problem (we can take more square roots), but give us another (we can't make square roots be near each other, for angles near each other on different sides of some "bad" angle).
if only the exponential wasn't periodic in i, right?
