What do you think about my class choice for next semester?
The discussion centers on a student's course selection for the next semester, which includes Heat Transfer, Fluid Mechanics, Mechanical Design I, and Vibrations. Concerns are raised about the potential difficulty of these courses, especially since the student is also working 15 hours a week. It's noted that Heat Transfer and Fluid Mechanics share overlapping concepts, which may aid in understanding, while Mechanical Design I is expected to be manageable. Vibrations is highlighted as a challenging course that requires strong mathematical skills. Overall, the consensus suggests that while the workload will be significant, the course selection is reasonable and manageable for the student’s interests and capabilities.
jklops686
I registered for Heat Transfer, Fluid Mechanics, Mechanical Design I, and Vibrations in Mechanical design. I'm not sure if this is going to be too rough or not. Vibrations is an elective and I think it is important. Another option would be FEA. I'm in thermodynamics now and I enjoy it. I'm thinking that fluid mechanics and heat transfer will be similar in ways, so although they are tough, I will do well because I enjoy it (hopefully). What do you think? Any experience based thoughts would be great. I don't want to set my self up for failure.
I'll be working 15 hrs a week too, cutting down from 20. I'm not a genius. I'm having a rough semester now but I'm bored with a lot of it. (circuits, statistics, mechanics of materials, thermodynamics)
I know people are going to ask what I plan on doing for the rest of my life. I know some kind of product development. Maybe engines (electric ICE, or jet), aero structures, energy systems, cooling systems, spaceships...I really don't know. : )
Heat Transfer and Fluid Dynamics will have several overlapping concepts, so that will be nice to have together. They can be pretty tough to grasp conceptually, though, so it's tough to say whether you'll have a tough time, or whether you'll be ok.
Mechanical Design I, depending on your curriculum, probably won't be too hard (entry level course), and if you have any natural aptitude for mechanical devices, you should not have too much trouble. I loved all my mechanical design classes. Gears, pulleys, bolts/nuts, fatigue, practical application of stress and strain, pressure, etc. Fun and practical concepts.
Vibrations can be tough. I had a dual major in Aeronautical and Mechanical, and my vibrations course was focuses on airfoils and fuselage structures. It was a tough course with lots of math; but it was very interesting.
You'll have a decent workload, and it might get pretty tough at some points, depending on how the courses are structured (and how the schedules overlap with exams, homework, labs, etc) but it's a reasonable semester as far as I can tell. I had several just like in when I was in school.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
