What does this equation tell me 2^a=3^b-1
  • Thread starter Thread starter .d9n.
.d9n.
what does this equation tell me 2^a=3^b-1?
its meant to be telling me something but I am not sure what
Well more of the question would be useful, but it you want a solution of either variable in terms of the other take logs on both sides and solve.
this is what i haveWe are looking for solutions of:
2^x + 3^y = z^2 [1]
where x, y, and z are non-negative integers.
So z^2 ≡1 (mod 3) unless z^2=3m for any integer m, and if x is odd, say x=(2k+1) for some integer k. However when z=3, we have 2^3+3^0=3^2, so one solution is when x=3,y=0 and z=3 When x is odd 2^(2k+1)≡2(mod 3) and when x is even 2^x≡1 (mod3) so z^2 is congrgent to 2^x when x is even.
We now know x is even, let x=2k. So we have:
3^y=(z-2^k )(z+2^k )
Now (z-2^k ) and (z+2^k ) should both be powers of three, so therefore (z+2^k )-(z-2^k ) should equal a power of three, so
3^w=(z+2^k )-(z-2^k )
3^w≠2^2k=2^x
So 2^x should be divisible by three, but it isn’t. So let (z-2^k )=3^a and (z+2^k )=3^b then we have
█((z+2^k )=3^b@(z-2^k )=3^a )/(2^(k+1)=3^b-3^a )
If a>0 then 3^b-3^a will be a power of three and 2^(k+1) is not divisible by three, so let a=0. We are left with
2^(k+1)=3^b-1
Let a=k+1, then we have 2^a=3^b-1.So this means that b≥0, otherwise 2^a won't be an integer, which means a≥1. Also a≤3 because if k>2, then 3^b≡1mod(8) which is a contradiction, so therefore a has to be either 1,2 or 3, making k=0,1 or 2.
When k=0 we have
2^1=3^b-1 → 3=3^1 so therefore b=1 and
When k=1 we have
2^2≠3^b-1 so therefore k=1 doesn’t exist.
When k=2 we have
2^3=3^b-1 → 9=3^b so therefore b=2.
2^x + 3^y = z^2 [1]
3^w≠2^2k=2^x
2^(k+1)=3^b-1
When k=0 we have
When k=1 we have
When k=2 we have
its the bit where i get to a<=3, I am not sure what this is meant to be telling me
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
