What does this tensor symbol mean?
The discussion centers on the interpretation of the tensor symbol \(\otimes\) in the context of incompressible flow dynamics as presented in a paper. Participants clarify that \(\textbf{u} \otimes \textbf{u}\) represents a tensor, specifically a momentum flux tensor, and not merely a vector. There is confusion regarding the relationship between \(\textbf{u} \otimes \textbf{u}\) and \(\textbf{u} \cdot \nabla \textbf{u}\), with corrections made to affirm that the former is indeed a tensor. The conversation highlights the complexity of the notation used in the Navier-Stokes equations, with some expressing frustration over the authors' choice of representation. Ultimately, the discussion underscores the importance of understanding tensor notation in fluid dynamics.
rsq_a
In a paper, the authors write:
At the continuum level, the dynamics of incompressible flow has to obey conservation laws of mass and momentum:
\rho \partial_t \textbf{u} = \nabla \cdot \tau
and
\nabla \cdot \textbf{u} = 0
where the momentum flux -\tau = \rho \textbf{u} \otimes \textbf{u} - \tau_d. Here \rho is the density of the fluid which is assumed to be constant, \textbf{u} = (u,v) is the velocity field, and \tau_d is the stress tensor.
From what I know of the standard incompressible equations, it seems that
\rho \textbf{u} \otimes \textbf{u} = \rho (\textbf{u} \cdot \nabla)\textbf{u},
but otherwise, I have no idea what the \otimes symbol means.
zhermes said:
That's a 'tensor product,' or 'outer product.'
See http://en.wikipedia.org/wiki/Tensor_product
Maybe some one has a good conceptual description?
I thought about that, but that doesn't make sense. If we interpret the symbol as the outer product, then (u,v)\otimes (u,v) is a 2x2 matrix. But as I pointed out, it seems that
\textbf{u} \otimes \textbf{u} = \textbf{u} \cdot \nabla \textbf{u}
which is simply a vector.
The quote in the original post tells you for certain that \textbf{u} \otimes \textbf{u} is a tensor, as the tensor \tau_d is being subtracted from it (and you can't substract a 2x2 tensor from a vector). Your deduction that \textbf{u} \otimes \textbf{u} = (\mathbf{u} \cdot \nabla) \mathbf{u} is incorrect. How did you arrive at this conclusion?
Mute said:
The quote in the original post tells you for certain that \textbf{u} \otimes \textbf{u} is a tensor, as a tensor is being subtracted from it. Your deduction that \textbf{u} \otimes \textbf{u} = \mathbf{u} \cdot \nabla \mathbf{u} is incorrect. How did you arrive at this conclusion?
Okay, maybe there's a simple way for you to explain it to me. Can you simply break down the original equation into vector form (2d is fine).
From
<br /> -\tau = \rho \textbf{u} \otimes \textbf{u} - \tau_d<br />
it is clear that
<br /> \textbf{u} \otimes \textbf{u}<br />
has to be a tensor; I don't know where or why you have,
<br /> \textbf{u} \otimes \textbf{u} = \textbf{u} \cdot \nabla \textbf{u}<br />
but my guess is that it can't be correct.
zhermes said:
From
it is clear that
There was a typo in my 'guess'. It should have been
\nabla \cdot (\textbf{u} \otimes \textbf{u}) = \textbf{u} \cdot \nabla \textbf{u}
Checking it over, that's correct.
What a confusing way to write the Navier-Stokes equations. I have no idea why the authors didn't just write them in the typical way everybody else uses without the tensor notation.
