What Eigenvalues Lead to Square-Integrable Eigenfunctions?
5 replies · 4K views · last reply
Felicity
solve the eigenvalue problem
∫(-∞)x dx' (ψ(x' ) x' )=λψ(x)
what values of the eigenvalue λ lead to square-integrable eigenfunctions?
∫(-∞)xdx' (ψ(x' ) x' )=λψ(x)
differentiate both sides to get
ψ(x)x=λ d/dx ψ(x)
ψ(x)x/λ= d/dx ψ(x)
2xe x^2 =d/dx e x^2
so ψ(x) = e x^2 and λ = 2
but this is not square integrable so either this is incorrect or there are other solutions I am not seeing
Can anyone help me find what I am missing?
Thank you
You want to solve the differential equation, ψ(x)x/λ= d/dx ψ(x) Separate the variables. You should get a solution with a lambda in it. Figure out what values of lambda make it square integrable.
Hello,
I think there are other solutions.
Take your equation,
[tex]x\psi\left(x\right) = \lambda\frac{d}{dx}\psi\left(x\right)[/tex]
and substitute [tex]\psi\left(x\right) = \exp\left(f\left(x\right)\right)[/tex] and see if you don't get an equation for [tex]f\left(x\right)[/tex] which has a solution that depends on [tex]\lambda[/tex].
Also, don't forget your solution has to be finite at the lower endpoint of the integral ([tex]-\infty[/tex]) in the original problem statement.
ok i separated variables, integrated and got
ψ(x)=e1/(2λ) x2
however I don't see how this can be square integrable since for any value of λ I can think of the integral of the square will equal infinity. I feel like I am missing something obvious here but I don't know what it is
ψ(x)=e1/(2λ) x2
Will it equal infinity even if lambda is negative?
