What engineering is most in demand
  • Thread starter Thread starter EngTechno
    Engineering
Aerospace engineering currently faces a significant drop in job demand compared to mechanical and electrical engineering. While aerospace and electrical engineering are considered challenging fields, mechanical engineering offers broader job opportunities. The demand for engineers varies by location, but overall, mechanical and electrical engineers are more sought after in the job market. This trend suggests that those pursuing engineering degrees may benefit from focusing on mechanical or electrical disciplines for better job prospects. In summary, mechanical and electrical engineering remain the most in-demand fields.
EngTechno
Is Aerospace engineering not as many as Mechanical engineering and Electrical engineering in market demanding?
Well if you mean how hard it is as in work then aero/electircal are very hard but then in jobs go do a broader degree like mechancial or even electrical
I think the question is one to do with the demand for aerospace engineers in the job market. I suppose it depends where you are.
In general terms, aerospace engineering has seen a significant drop in job demand.
Both electrical and mechanical engineering are in high demand.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
