What Factors Influence the Re-entry of Apollo 13's Command Module?
  • Thread starter Thread starter bheidkamp3
    Apollo
Key factors influencing the re-entry of Apollo 13's Command Module include atmospheric drag, angle of entry, velocity, and thermal protection. Understanding the trajectory and speed is crucial for calculating the correct re-entry path. The impact of gravity and the Earth's atmosphere on the module's descent must also be considered. Resources such as NASA's official website and physics simulation tools can provide valuable data and equations. Gathering this information will aid in creating an accurate spreadsheet for the project.
bheidkamp3
My Physics class is doing a Nasa project where we divided up the path a saturn-v shuttle takes. My group is working on the re-entry after the pod has been ejected. Our end result will be a spreadsheet of the return to Earth till landing. If anybody has some helpful websites or just want to list out factors we need to take into account it would be helpful. Any equations will also be appreciated. Thank you
anybody?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
