What happens if a motor is not supplied required amps?
  • Thread starter Thread starter MHassaan
    Amps Motor
Running two 3000RPM, 24V, 15A DC motors from a single 24V, 23A power supply may lead to insufficient current for both motors, potentially limiting their performance. If each motor receives only 11.5 amps, it could decrease their torque and RPM, risking overheating or damage if the motors stall. The power supply may not support the load, as it is rated for 600W, which is less than the combined requirement of 720W for both motors. It's crucial to verify the output configuration of the power supply, as multiple outputs may not provide separate current ratings. Consulting the manufacturer for technical assistance is advisable to avoid damaging the motors or the power supply.
MHassaan
Hi everyone,
I am in a situation where I need to run two 3000RPM, 24V, 15A DC motors from one 24V, 23A switching DC power supply, rated at 600W.
Firstly, the power supply has three sets of DC outputs and one set of AC inputs. By sets I mean one positive and one negative. This means I can power three different circuits from it. What I am confused about is how much power each of the motors can receive if they are connected to separate ports. Will I get 24V, 23A at each port? Or will the voltage be same but the current shared across the motors?
The second thing is, if each motor receives only half the current (11.5 amps), and 24V, what effect will that have on the performance of the motors? Will it decrease their max RPM or torque or both, and by estimated how much?
I am a complete beginner in electrical engineering so please go easy on me...
Thank you very much for all your time!
I'll just take some guesses for fun...I have learned to enjoy being wrong. Take this advice with a grain of salt and wait till great minds prevail. Still, just for fun...
Have you tested the 4 outputs with a volt meter...or at least a small light bulb?
Does it have voltage at each port all the time...or only one at a time as "switched" implies?
If it is only one at a time, you should be able to still run two motors in parallel. AC motors hate drops in voltage...but a DC motor should run at just slightly less RPM and torque. Why do I say this? Because I remember playing with tyco trains as a youngster and watching the train speed change with the change in the throttle...voltage I presume.
24 volts X 15 amps = 360 watts...X 2 (motors)= 720 watts. 600/720 = 83%
But I think you might burn up your power supply if you are constantly running it maxed out at 600 watts all the time.
You can safely run one motor off of it...I think everyone will agree with that.
MHassaan said:
Hi everyone,
You really should contact your suppler about this question. You risk damaging the power supply and possibly the motor if you are wrong about how the power supply works. Find the manufacturer on the tag attached to the power supply and look it up on the internet to get the phone number. When you call ask for technical assistance about [model number] power supply.
The max RPM is determined by the voltage across the motor and the current determines the torque.
As long as the load doesn't require more torque or current than the power supply can deliver you should be alright. What happens when you exceed the max current of the power supply depends on the power supply. It may blow a fuse or it may lower the voltage, and therefore the speed of the motor until its current is sufficient to drive the motor at a lower speed. If that speed is zero RPM or a stalled motor, the motor will heat up and you could destroy the motor. If the power supply has no internal protection it could also blow the transistors in the supply.
Your 24 v, 23 A is 552 W - 600 W is the nominal rating.
If the three DC outputs do not have separate ratings of volts, amps, watts then they are most likely not separate circuits, but internally connected and the outputs are just supplied to you for your convenience. Check the ratings tag on a standard swithced PC power supply to compare.
Judging from all your answers, it is clearly not a good idea to attach the two motors at once to this power supply.
Does anyone know of a power supply with a greater amp rating but the same voltage?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
