What happens to a Black hole when they die?
In summary, when a black hole dies, it disappears in a powerful burst of Hawking Radiation, leaving nothing behind. The Hawking Radiation does not release any information about the inside of the black hole. It is theorized that once a black hole reaches the Chandrasekhar Limit, it will no longer be able to maintain its gravitational pull and will "explode" violently. The process of evaporation through Hawking Radiation can result in the creation of both particles and antiparticles, with some escaping and others being absorbed by the black hole. As the black hole gets smaller, the rate of radiation increases until all of its mass is lost. However, it is still debated whether a "naked singularity" is the end result of
Rashid
So What happens to a Black Hole when one dies?
I've heard that they just dissentigrate, collapse, etc.
What actually does happen to a black hole when it dies?
Astronomy news on Phys.org
Greetings Rashid !
Theoreticly, it just disappears in a powerful
burst of radiation energy. Since the radiation
is Hawking Radiation no information about the
"inside" of the BH is revealed in the process.
Live long and prosper.
Yeah, because I was thinking, if a black hole was to let loose the Hawkin Radiation, would that radiation not fly all over the universe? And, what would be left behind? Would the singularity expand since it had condensed all that matter over the billions of years? Thanks for the reply. =)
Actually you have it backwards. If a black hole disappears, its EVAPORATING, not condensing. There is simply nothing left.
Now, I always thought that when a black hole collapsed or evaporated all the information inside (could be) released, wouldn't it be impossible for a black hole to evaporate through Hawking radiation, as Hawking radiation always leaves particles inside, while one escapes?
Isn't one a particle and one an anti-particle or virtual particle? I can't remember and I don't have my copy of ABHOT on me.
I can't remember exactly how it works, but if something emits energy, it MUST be getting less massive because of the equivalence of matter and energy.
An anti-particle is created outside of the event horizon, while the original particle is on the inside, therefore the inside particle stays and the anti-particle escapes, this continual division of particles would never equal zero.
Greetings !
Actually both are created outside the event
horizon as far as I know. Then one is absorbed
by the BH and the other one sometimes escapes.
But it would, eventually, produce a mass that is less than the Chandrasacre Limit, leaving an object without enough mass to be a black hole. According to Hawking and some others, the universe is not old enough for any black holes to have reached this critical point yet. I would imagine that once this threshold is reached, the black hole would end rather violently. At the center of a black hole is (theoretically) a mass much more dense than a nuetron star, because the structural resistance of atomic nueclei to compression has been overpowered by gravity. Once the force of gravity is no longer strong enough to keep these nuclei "crushed", it seems to me they should begin to expand. This expansion would accelerate rapidly as the expanding matter gets further from the center of gravitational pull.
You are mostly right on this except that the Chandrasekhar Limit is for White Dwarf stars. The low limit for a BH is ~3.2 Sm on formatiom. That applies to formation, not disentigration. The BH can radiate away enough energy (mass) and still fall far below 3.2 Sm until it "explodes" as described below.
Bigger black holes are colder and dimmer than small black holes. The Hawking temperature is inversely proportional to the mass, while the Hawking luminosity is inversely proportional to the square of the mass. Also, not all virtual particles/antiparticles will "split" with one escaping and the other falling back in. In some cases, mutual annihilation will occur outside the event horizon and the total mass will be lost. From the above, we can see that the BH radiates more rapidly as it gets smaller, and the mass-loss increases until the last of it is radiated away (mostly gamma ray), with the last of the matter radiating so rapidly that the result would appear as an explosion.
if steven is correct
the end result is a NAKED singularity
and that's something we just don't understand
LURCH...
Might the above not describe the "end" of THIS INCARNATION of the UNIVERSE...Everything collapsing into a singularity that bursts forth into ANOTHER "Big Bang"??
I think all the Black Holes will eventually "hook up" and everything will collapse into a singularity AGAIN.
And/Or Dark Energy will cause the Universe to expand to a point where It is cool enough for a PHASE TRANSITION whereby Dark Energy becomes Dark Matter (or something...just as "matter" "condensed out of" the energy of the "Primal Singularity" right after the Big Bang).
I think GRAVITY will have the last word...and that word will be "CRUNCH"!
What happens when the increasing charge density of gravitational collapse causes the electronic energy to approach surpassing the local rest energy of that quark soup, i. e., when the average charge-charge radius might go beneath that of a corresponding electronic black hole? Is the electronic black hole a quantum limit to black hole structure?
Perhaps.
Just some questions i need answered
I never knew that black holes could actually die, because aren't they usually made up of a large amount of gravity? but where does the gravity acutally come from? Is it because there's acutally magnetic fields within these black holes, or maybe there's acutally "negative mass" in these things?
I know questions like these probably seem awkward and strange but I'm still a child trying to figure things out and trying to get my questions answered. So i'll really appreciate it if u can provide me some info in terms that I can understand.
But how exactly do black holes die out? Because the Black Holes are actually absorbing things while they're around, doesn't this prove the theory that our universe is flat false? I also remember reading from somewhere that within the black holes there is no such thing as time, why is that?
Well, you have a lot of questions here that have been addressed already, but to sum up:
-Black holes are made of ordinary matter, highly compressed
-Gravity is a property of mass (which is why you weigh 6x as much on the Earth as on the moon - the moon has less mass).
-Black holes die out because of a complex process where they radiate energy - and energy is a transformation of matter.
-Black holes do not necessarily absorb everything around them - especially if there is nothing around them to absorb.
-Since time varies and is slowed down by gravity, when gravity gets strong enough, time stops.
Likes Polinast96
hahaha, I'm sorry, but I'm new to this website. So far..i've only been a member for 7 days, but i only logged on like 3 times hehe well thanks for summing it up. hehe
what if the point of singularity of a black hole is the creation of smaller "big bangs" which create other universes. When a black hole "dies", what if it were the creation of a big bang simultaneously to create a new universe. What if the "big bang" was a creation of a the death of a massive black hole. I mean we don't know if our universe isn't apart of a much bigger system. Who knows, maybe there are more universes too.
Related to What happens to a Black hole when they die?
1. What is a black hole and how does it "die"?
A black hole is a region in space where the gravitational pull is so strong that nothing, including light, can escape from it. When a black hole "dies", it means that it can no longer sustain its gravitational pull and it stops growing.
2. Can a black hole truly "die" or does it just continue to exist in a different form?
Currently, there is no definitive answer to this question. Some theories suggest that a black hole may eventually evaporate due to Hawking radiation, while others propose that it may transform into a different type of object, such as a white hole.
3. What happens to the matter that gets pulled into a black hole?
When matter falls into a black hole, it is compressed and heated to extremely high temperatures. This causes it to emit radiation, known as Hawking radiation. Some theories suggest that this radiation may eventually cause the black hole to evaporate.
4. Will the death of a black hole have any impact on the surrounding space?
It is unlikely that the death of a black hole will have any significant impact on the surrounding space. However, if a black hole were to suddenly disappear, the matter that was previously trapped within it would be released, potentially causing an explosion.
5. How long does it take for a black hole to "die"?
The lifespan of a black hole is dependent on its mass. Smaller black holes can potentially evaporate in a matter of seconds, while larger black holes can take trillions of years to "die". However, it is important to note that the exact process and timeline of a black hole's death is still not fully understood by scientists.
  • Astronomy and Astrophysics
