What integration technique to use?
  • Thread starter Thread starter ehrenfest
    Integration
ehrenfest
What technique should I use to evaluate
\int_0^1 dx \frac{x^{m-1}}{\ln x}
where m is a positive integer
x^{m-1}=x^{m}\times x^{-1}
Don't go around trying to find the anti-derivative of that in elementary functions, the indefinite integral evaluates to Ei (m \ln x) + C, \frac{d}{dx}C = 0 where Ei(x) is the exponential integral. This result follows because after the substitution u= ln x, the original integral becomes \int^0_{-\infty} \frac{ (e^u)^m}{u} du.
Best you can do is to get an infinite series solution.
Ahh I think I've found out how to solve it, because those bounds looked quite nice =] Try Differentiation under the integral.
Yes. That works. My original question was a mistake, however. I wanted to use parameter differentiation to find
H(m) = \int_0^1 dx \frac{x^{m}}{\ln x}
So, I differentiated erroneously and got
H(m) = \int_0^1 dx (m-1)\frac{x^{m-1}}{\ln x}
instead of
H(m) = \int_0^1 dx x^{m}
By, the way, H(m) = \ln{m+1}.
Ah no it's not as easy as that...You have forgotten to deal with the Constant associated with the integrals..
Well I might as well give another clue, try looking at H(-1) to evaluate the constant. If my mind was a bit clear yesterday, I could have told you that; looking at the natural logs series between 0 and 1, that integral is...
