What is a Clock? Syncing Technologies Explained
  • Context: High School
  • Thread starter Thread starter Torog
    Clock
The discussion revolves around the definition of clocks and the synchronization of different clock technologies. Participants explore the nature of clocks, the criteria for synchronization, and the underlying mechanisms that contribute to the stability of various types of clocks.
  • Some participants define a clock as any device that repeats regularly, while others emphasize the need for synchronization according to Einstein's principles.
  • A few participants critique the circular definitions of clocks and time, suggesting that time is treated as a non-spatial dimension that separates events.
  • There is a discussion on whether two processes based on different mechanisms can be considered clocks if they exhibit periodicity.
  • Some participants argue that the stability of clocks depends on their construction and the physical laws governing their operation, such as electrical properties or biological processes.
  • One participant questions the role of inertial weight in the stability of atomic clocks, while another asserts that weight/mass does not influence atomic clock operation.
  • There are references to various clock types, including pendulum clocks and atomic clocks, with discussions on their accuracy and the factors affecting their stability.
  • Some participants express uncertainty about the relationship between mass, angular momentum, and the functioning of atomic clocks.
Participants do not reach a consensus on the definitions and criteria for what constitutes a clock or the mechanisms that ensure their stability. Multiple competing views and uncertainties remain throughout the discussion.
Some discussions involve assumptions about relativistic effects and the arbitrary nature of time definitions, which are not resolved. The relationship between mass and clock stability remains unclear, with differing opinions on its relevance.
  • #91
Paul Colby said:
Google yields...
"Transition frequency may refer to: A measure of the high-frequency operating characteristics of a transistor, usually symbolized as f. A characteristic of spectral lines. The frequency at which changes in the hyperfine structure of atoms occur. Turnover frequency in enzymology."
Seems to match my usage? Did I miss a memo?
The frequency of the radiation corresponding to the hyperfine transition in the ground state of the cesium atom is not the rate at which changes in the hyperfine structure of atoms occur.
  • #92
Hyper fine structure is a property observed in spectral lines of an atom. This has zip to do with the rate of transition. Not all transitions need be to the ground state. It's an RF spectral line.
  • #93
Fair enough. I mis-read your reference to "frequency at which" as "frequency with which".
  • #94
Paul Colby said:
The hyperfine interaction is between the magnetic moment of the nucleus, which is a constant, and the electrons in the atom. The transition frequency should be a know function of electron mass.
So if the mass of the electron changes (in my imaginary world) does the transition frequency change?
  • #95
That depends on how* the mass changes. Specifically, does the mass change in a way that also changes the fine structure constant (or other dimensionless constants) or does it change in a way that they do not change? The measurable transition frequency depends on the dimensionless constants like the fine structure constant.
*how meaning the details about the other changes that might be associated, not the mechanism of change
  • #96
The interaction Hamiltonian which determines the frequencies of transition depends on the magnetic moments which depend on particle mass. Everything changes if ##\hbar## changes as well. These are all observed to be constant as far as I've heard.
  • #97
Why does this even matter? The mass of an electron is fixed.
  • #98
Torog, I appreciate your thinking, and then questions following on how we might define a clock. This is a good thread to help at least some of us attempt to properly anchor the roots of time itself.
First, I should correct my previous assertion (below) that all clocks rely on angular momentum... not certifiably true. It arose from a different, also unmentionable personal idea.
Wes Tausend said:
All our clocks have this common denominator. They all rely on angular momentum, or a portion thereof , one way or another, to stay synchronized and count off rotations or portions thereof (pendulum).
DrGreg properly rejected my reasoning on a surviving earlier post and I hereby acknowledge he is correct; strictly angular momentum cannot be the charred key we seek here. My bad. :oops:
I find of particular interest what Sorcerer and Dale have discussed above in posts #68 & #69. While I struggle to understand the abstract math symbols of Noether's Theorem, I think I do recognized the conceptual value of, "the principle of least action", as partially worded in this first paragraph. This paragraph seems very much along the lines of Occam's Razor, or as Maupertuis supposedly felt, that "Nature is thrifty in all its actions".
It seems that the ultimate object of science is to simplify whatever processes and observances of Nature that we can. For instance, we might strongly suspect Mother Nature is lazy, that she accomplishes her vocation in the simplest manner possible... and when sufficiently 'cooked', these actions should boil down to fundamental principles... in other words the very charred essence of what we seek. I really like the simplicity of conservation of energy idea for this and other reasons.
Prior to the conservation of energy posts, I was tempted to come back and suggest that, since all classical clocks seem to at least rely on non-erratic motion events, that perhaps conserved general momentums (not just angular) were still the key. Even a candle flame, water or sand must move non-erratically to usefully differentiate the increments as a clock. But 'conservation of energy' seems a much better key now that it has emerged from the soot... because 'conservation of energy' allows not just conserving momentum, but storing that momentum for reuse as counter-momentum if we wish. Clocks commonly work by stored energy and each burst is measurably the same as last. As food for thought, it seems perhaps an escapement loop principle somehow regulates them all.
In a non-classical view, regarding quantum behavior of atoms when remarks on motion were given by Mister T, I am still not so sure I can draw an obvious conclusion that there is an obvious discernible atomic counterpart to classic laws of motion, but that is just me. In my quantum fog, it seems we should only know either the position of the 'tiny' hands or the rate, but not both at the same time. Yet atoms furnish us a great timepiece, apparently by rate alone. It is like a blind man that can hear, and use, the precise tick-tock but need not see the position of the hands to tell time.
But then conservation of energy was brought up. Ok, I know energy transcends both mechanical and quantum. This is better. Just "hearing" the tick-tock of an atom is the process of periodic electromagnetic energy escaping, enough as to form a useful timepiece, particle position notwithstanding. The electromagnetic energy will escape and tell us time until it runs out, or ceases to be applied, like any other clock. Perhaps someone could explain if both atomic and mechanical share a comparable hidden escapement mechanism to not release their energy nearly all at once. Seems maybe worth a Nobel Prize... unless it's been done.
Torog said:
You qualify the above with (pendulum). Isn't it possible that if you drill down into the mechanism of all clocks you will find Inertial mass somewhere in the regulating mechanism.
Thanks, this is what interests me, the how or physics of the regulating mechanisms of clocks.
It is still not so clear to me why 'drilling down' would not succeed, why Nature would suddenly abandon her simplicity right at the bottom of the hole. It's difficult to leave Einstein's side and not share his desperate want to discover why random motion seemingly rules so non-erratically at the core. How can something so random as the ghostly gears of an atom be our best clock? Perhaps we will only really know the atomic mechanism in a heuristic mechanical sense, if or when Einstein's dice ever reveal their secret. Quantum gravity heck; what is quantum time? Non sequor... :wideeyed:
It seems a thread like this, where there is not a specific single answer to cite, elicits more opinions that border on speculation. The safer route seems to be saying not much, which I've tried to avoid. I hope I am ok today.
To be upfront, I was the (or a) guilty party in earlier setting foot outside the rules box and got a time-out. I apologize, my zeal to somehow add insight occasionally precedes my head. My uncited previous post, especially about cosmology, was removed and I deserved it. I do very much continue to appreciate the tedious behind-the-scenes work done here by Mentors even when it turns out I'm the rascal gone Beagle Boy. So thanks, Mentors.
And thankfully Torog's worthy clock thread was not locked on my account. :smile:
Wes
  • #99
This is just what I was trying to understand. The stability of the electronic clock is at least partially based on the fact that the mass is fixed.
I would like to say more but it is not a subject for this forum.
  • #100
@Torog you didn’t answer any of my requests for clarification on this topic.
  • #101
Dale said:
All clocks have mass, so they all have inertia. So what do you mean by “inertial factor”? Do you merely mean that it has inertia? If so then it is a fairly trivial statement that doesn’t describe much about clocks. Do you mean something more?
Clocks have inertia. Cars have color. Color is not the operating principle of a car. Are you simply stating that clocks have inertia or are you trying to say that inertia is the operating principle for all clocks? Are you merely saying the equivalent of “all cars have a color factor”.
Is this the question you want me to answer? Rather offensive actually. You imply that aside from being ignorant (which I admit) I am also stupid.
What I have been trying to ask is inertia a factor in the stability of clocks? It is in my pendulum clock, my balance wheel watch and in the stability of the orbital period of the Earth. Does it apply to Atomic clocks? Or other clocks?
I also asked this about the speed of clocks. Never got an answer.
Torog said:
Look at it from a GR (or SR?) perspective and with the principle of equivalence gravity and inertia can be interchanged so if the intensity gravitational field effects the clock - proven,of course – then why can’t we postulate that if the inertial mass of the clock changes then its rate will change?
  • #102
Inertial mass is not a factor in the tick rate of a light clock.
Or, to put it differently, inertial mass is as much a factor in the tick rate of a light clock as it is in the length of a ruler.
  • #103
This is not acceptable. I never said nor implied any such thing, nor did I even think it.
You are asking a question about a broad topic using non standard terminology and it appears that the responses have been unsatisfactory to you. There are two possibilities, one is that your question was correctly understood and you just don’t like the answer, and the other is that your question has not even been understood so the responses have been responding to misinterpretations of your question. I believe that second possibility is the case here.
The proper thing to do in that second case is to ask for clarification. To challenge the questioner to address their unspoken assumptions and express the meaning behind their terminology. That is a correct intellectual approach, to which you have twice responded exceptionally emotionally.
You have not been bullied, nor cut off, not called ignorant, nor stupid. You have been asked for clarification and asked to examine and express the meaning of your question. Instead of responding substantively and helping to clarify your question, you have inaccurately assigned very negative motives to me and avoided the question.
  • #104
In what way is inertia a factor in a pendulum clock? A pendulum clock has mass, but its frequency does not depend on its mass. So are you asking about the color of the car or the engine of the car?
A light clock also would have mass, but its frequency would be independent of the mass. So is that all you mean by “inertial factor”, does merely having mass qualify or is there a further qualification implied by your terminology. If so, what is that qualification?
I don’t think that is a correct statement of the equivalence principle. Roughly the equivalence principle says (with some qualifiers) that gravity is equivalent to acceleration. But acceleration is not the same as inertia, so I wouldn’t say that gravity is equivalent to inertia.
  • #105
@Torog, please moderate your language. You are very close to a warning. @Dale is trying to help you.
As both @Dale and @jbriggs444 have responded, the answer is no.
  • #106
At least I got this about atomic clocks which had previously been excluded by other posts.
@Peter thanks for the warning of a warning!
  • · Replies 39 ·
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 84 ·
  • · Replies 26 ·
