What Is a Function Generator Used For?
A function generator is a device used in laboratories to create various types of electrical waveforms, commonly for testing and experimentation. Users are encouraged to research its operation and consult user manuals from manufacturers like Tektronix or Agilent for guidance. It is also suggested that teaching assistants may provide demonstrations on how to use the function generator and related equipment, such as oscilloscopes. Engaging in self-directed learning before seeking help in forums is advised as a valuable practice. Understanding the function generator's applications and operation is essential for effective use in a lab setting.
samieee
hi all
I have seen in my dc lab that there are some devices which are called function generator I want to know what is function generator? for which purpose this is used and how to operate it?
http://www.lmgtfy.com/?q=how+to+use+a+function+generator
Not to be condescending, but come on, you can at least start by searching for this sort of stuff! Assuming the function generator isn't too old, you can probably even find a user manual at the manufacturer's website (Tektronix? Fluke? Agilent?)
If nothing, your TA will probably demonstrate its use sometime in the near to longer-term future. They'll probably also demonstrate the use of the oscilloscope (if they haven't already).
+1
Please get in the habit of doing some work on your own before asking a forum for help. That's good advice in general, in the working world...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
